FS: Miscellaneous wares for boat anchor building
R80-44 R-Core transformer $25
(0-360-400)X2(50mA), 0-15(2A), 0-5(2A), 0-6.3X2(2A)
11.5(L)x9(W)x5(H)
Great for preamps
I have a pair of very particular 5K OPTs. They are electraprint and gapped for 125ma. They were to be a low volt GM70 SET amp. I prioritized HF response to LF response as I typically use subs, so they are not meant for full power below 50hz. They are big and heavy though.
The problem is that I noticed that the lams seemed to have moved in shipment, they don't seem flush with one another. Therefore I think these might need to be rewound. There is a lot of good iron here though, so it would be a shame to go to waste. Best offer. They weigh about 4kg each.
2x #military sealed 'FTR' filament transformers for the diode dampers, secondary is 6v @9amps, 111wv. Sealed and secondary is shielded which makes great filament transformers.
$70 for the pair + shipping.
Onetics FWB hybrid circuit B+ plate transformers (was planning to build the Karna PP300B amp) scrapping plans....
2x #10216-B at 500 vac @ 220ma ac @ $198.70ea orig price Asking $120 for the pair plus shipping.
CHECK out my last few posts for pics/prices of some of the remaining. Post #1 is updated as well.
