FS: Miscellaneous wares for boat anchor building
Ok, in all seriousness, my days of DIY are long in the rearview mirror and I'd very much like to clean out space.
I probably have a lot more of this kind of thing in storage, but here in front of me is some stuff from a project never started surrounding the use of GM70 tubes most likely. Some from low DCR style power supplies.
  1. 1x Hammond 166Q6 6.3vct @ 6A NIB $20
  2. pair of monster transmitter type chokes. 6hy, 300ma and 7kv test voltage, 35ohms! They weigh 16.5lbs each without packing. They are fully encased, hermetically sealed, but need a painting if you want to display them (I think the ceramic on one of the stems is cracked a bit and needs a little TLC but wouldn't effect function). $140/pr [Can't seem to locate them at the moment, they are somewhere in my storage...so pause on these until I find them]
  3. R80-44 R-Core transformer $25 [SEE Post #21 for pic]
    (0-360-400)X2(50mA), 0-15(2A), 0-5(2A), 0-6.3X2(2A)
    11.5(L)x9(W)x5(H)
    Great for preamps
  4. 2x #military sealed 'FTR' filament transformers for the diode dampers, secondary is 6v @9amps, 111wv. [SEE Post #30 for pic]
  5. 4x 8Hy high current low DCR inductors from asia I bought a very long time ago, they are r-core or C-core by the looks of it. [SEE Post #31 for pics]
  6. Have one large R-Core Transformer for building a tube amp. R260-038 [SEE Post #15 for pic]
    Dual 0/110/120V primaries, Dual 400V@200ma/360V/0V secondaries. 90V/90V@100ma, dual 2.5V/2.5V@2.5A, 0/5/6@4A, 3.15V/3.15V@4A. $60
I am trying to figure out pricing to make packing it up and shipping also worth the effort. Happier to bundle a few items.
Pricing is USD, pricing in CAD is *1.3, but I'll take either. Shipping extra, local sales appreciated.
Found another Triad C-47U in storage. Plus some more stuff.
Allied Elec. 6K7VG $60 usd
Hammond Manufacturing - Transformers - 6K7VG - TRANSFORMER; PRI:110-120V; 50/60HZ; 750VCT @150DCMA; 5V @3A; 6.3A @ 5.0A; LEADS - Allied Electronics & Automation
Transcendar OPT pair $140 USD
3 K to 8 ohms
Frequency Response: 20 Hz to 100 kHz +/- 1 dB @ 1 Watt
Maximum DC Bias Current: 100 mA
Primary DC Resistance: 300 ohms
Primary Inductance: 20 H @ 120 Hz
Part Number: TT-010-OT
Transcendar Transformers - 10 Watt SE
A bundle of Russian 4P1L NOS wrapped in box, circa 16+
16+ x 6X9P-E NOS
16+ x 6C4P-EB NOS
6 GE Engr Sampl 6LW6 $100
4 GE 6LW6 + 1 Admiral (2 GEs and 1 Admiral are same construction as above Eng.Sampl. the other two are greyer plates and slightly different but close).
5x 6BY5GA $10
5x 6DQ5 $25
2x 6FW5 $8
2x 5Y3G (Syl + Silvertone)
6x Jan 6112
1x 83 $6
1x Philips 78
highest bid on:
24 0D3
4 0C3
1 0A3
1 0B3
2x CV4024
2x 6C33 $20
Onetics FWB hybrid circuit B+ plate transformers (was planning to build the Karna PP300B amp) scrapping plans, but I do have the power supplies mostly laid out onto an aluminum baking tray ready to wire up.
2x #10216-A @ $198.70ea for 600 vac @220 ma, (orig price, looking for 0.6/$1)
2x #10216-B at 500 vac @ 220ma ac @ $198.70ea . (orig price, looking for 0.6/$1)
some photos
couple of photos of my tube collection to be sold.
QTY Model Description
42 6S4A Most is RCA, second is GE then some more random makes like Sylvania
10 5842 6x Raytheon Jan 5842WA, 4 Jan 5842 Amperex
4 5687 3x TS, 1x GE 5 Star
4 7044 GE
1 7199 Sylvania
20 6N6P
11 6H1P
8 6H30Pi
2 6922 EH Gold
3 6H23P
2 ECC81 Siemens
2 CV4024 Mullard
13 12B4A
34 12GN7A
15 12A4 mostly CBS Hytron, others GE
13 6CG7 +2 8CG7
4 EC91 6AQ4 RCA
8 6CB6A RCA
5 6T4 GE Sleeve
8 12HL7 Sylvania
10 6J52P
13 6FH5
8 EF184 GE
6GK5
3ER5
3A5
6CM7
3GK5
I am working out pricing, but just hit me up with what you are looking for and we can work it out. I am also taking photos of key tubes. I have a Hickok tester, so the spendier tubes can be tested, but I am not testing large lots.
I'm fishing more things out of my storage unit.
Edcor XPWR007 Sec: 550V@200ma, 6.3V@6a, 5V@3A $pending
11.5(L)x9(W)x5(H)
Great for preamps
I'll post pictures later or upon request (pm me your email in which case).
More boat anchor supplies...
I have a pair of monster transmitter type chokes. 6hy, 300ma and 7kv test voltage, 35ohms! They weigh 16.5lbs each without packing. They are fully encased, hermetically sealed, but need a painting if you want to display them (I think the ceramic on one of the stems is cracked a bit and needs a little TLC but wouldn't effect function). $140/pr
