Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Solid State Talk all about solid state amplification. |
Thread Tools |
#1001 | |
Hi Sheldon,
Thank you. Quote:
Much appreciated. Best wishes, Susan. |
#1002 | |||||||
![]() Quote:
![]() Quote:
If oscillation turns out to be a problem, gate resistors, ferrites and gate-source capacitors are all viable tools to eliminate it. Quote:
The inductance is more difficult, I'd imagine. What kind of inductance would one need to get full range operation? Quote:
Come to think of it, wouldn't it be possible to drive the voice coil with the same signal as the "magnet", or would this be yet another case where the inductance cannot be made to reach the desired level?
-- "Do not attempt to stop this cicular saw with your hands or genitalia." - Warning Label |
#1003 | |
Sheldon |
#1004 | ||
As I understand the design, both transistors are in conduction at all times, which fits some definitions of class A, as neither transistor will cut off at any point, entirely eliminating crossover distortion. However, I believe the conduction angle (at least in terms of linear operation) is less than 360 degrees, which excludes the class A designation in its strictest sense. Please correct me if I'm wrong, and also note that I do not mean to imply inferior sonics or design by my statement. Quote:
In the strictest sense, the circuit is not class A, as its conduction angle is not 360 degrees at maximum output. However, herein lies one of the more elegant aspects of this design, in my opinion: Unlike a conventional class AB amplifier, Susan's design has a continously variable conduction angle, in that the conduction angle is proportional to the signal, and the conduction angle always exceeds 180 degrees, meaning you get no cross-over distortion. In fact, I believe you can select the minimum conduction angle by adjusting the bias, though I haven't tried to derive a formula for it.
#1005 |
Regarding additional series resistance to lower the bias on the JFETs, I'd suggest putting a single, shared resistor between the primaries and the rail, not one per leg. I believe Sheldon was the one thinking about this.
#1006 | |
Using the method of paralleling devices but having each device on its own winding is an attractive method of ensuring that each part doesn't current hog as each one has it's own separate load to look after. However there is a problem with oscillation as each device tries to optimally do its follower 100% degenerative feedback thing. Note that this is completely separate to the oscillation some devices are prone to from having too low a value of gate resistor. The resistors are to couple adjacent device sources i.e. between the devices, they are not in series with the windings or across the transformer to ground. Therefor there will be no current flow (of any significance) as all the sources are at the same voltage point (within a few mV anyway). However what this does is provide a low resistance path between the sources and ensures that they all stay in step with each other since the windings above DC actually have significant impedance. So in the simplest case of having two pairs of devices, one pair per side, each on its own winding one would use two resistors. One is across the first pair's sources, the other is across the second pair's sources. (Will draw up a schematic at the weekend.) Hope this is a little clearer. Best wishes, Susan. |
#1007 | |||||
Plus, seperate windings should give better high-frequency performance, according to some pages I read. I could be wrong here, though. Quote:
Although I'm no good with transformers, so if you're feeling awfully bored, you could explain the details of the hows and whys of this kind of resonance. ![]()
#1008 | |
Sheldon |
#1009 | |
The other type is a brand used by mostly by hobbyists and jewelry makers. The brand is Tix. It seems to sell for about $15 for 20 8cm pieces. The only information I could find seems to indicate that it comprises indium, lead, and tin. It has a melting point of 135 degrees C. Unless someone knows some reason why this wouldn't work, I'll give this type a try. Sheldon |
#1010 | ||
Since this topology generally employs a sub-360-degree conduction angle, you may want to incorporate some advice from another forum member (again, I forget who). Basically, solder the devices to a large copper bar, then solder that to the heatsink. While this may slightly reduce constant dissipation, it will improve transient thermal performance, as the mass (and higher heat conductivity) of the copper bar will absorb larger heat transients. Whether this trick works for you is, I guess, dependent on the bias setting you choose. Of course, a 12dB fan would also help a lot, possibly enabling you to go as high as 30W idle dissipation (operating temperature of 80 degrees).
Thread Tools | |
New To Site? | Need Help? |
