LatFet Amp Based on Philips AH578
"Are you building both versions?"
No, i have not 20n20\20p20 transistors.
"small pieces of aluminium to the driver transistors."
small pieces of aluminum for driver transistors can always be attached anyway... But if it's hot, put them on the radiator by turning 90 degrees
