Hifisonix kx-Amplifier
I installed onsemi 1220 and 2690.
Are R10 and R11 too high?
(mesurement in low mode)
R16 and R17 measure 415 mV.
BC546 and BC556 are B grade.
KSC3503 is D grade.
KSA1381 is E grade.
However with Onsemi KSA1220 KSC2690 it seems to me improved. BD139/140 weren't as good.
Oloppolo, your amp looks like it’s ok. R16 and R17 are a bit high, but I think you are ok to go. Output current is 463mA per pair which is ok.
You now need play some music through it and wire it up in its final configuration. If you have any hum problems, come back here or PM me to help to solve it.
