Rails do not have to be balanced at all, even wild differences like +15 and -25 or +25 and -15 should make no difference to the operation apart from asymmetric clipping as the output hits one rail before another.
OK so I would need to see the correct version to make an informed choice over what transformers might be suitable. As you have a PSU (and assuming it generates a split supply) then try it and see what happens.
Good infomation but the schematic is not an A1 V3.0, or maybe more accurate/politer to say, its not the machine I have in front of me.
