Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Finding the inductance of a coil with a soundcard ?
Thread Tools
Old 20th July 2021, 10:33 PM   #1
diyiggy is offline diyiggy
diyiggy's Avatar
Default Finding the inductance of a coil with a soundcard ?
I'm playing with Limp to measure the impedance VS frequency of a coil with an Arta box, but is someone is aware of a shareware to find the inductance value of an unmarked coil, please ?
Pi VII au bord du Pô.
Old 20th July 2021, 11:47 PM   #2
trobbins is offline trobbins  Australia
trobbins's Avatar
REW has an impedance measurement function which I have used - it is accurate and can measure over a wide range of inductances (I've confirmed from 10uH to over 100H). Maybe other software tools have a similar function.
Impedance Measurement
Old 21st July 2021, 12:26 AM   #3
diyiggy's Avatar
many thanks, trobbins. I didn't know that and that's a good thing as I have to dive a little in REW after Xsim
Old 21st July 2021, 04:53 PM   #4
Lojzek is offline Lojzek  Croatia
Lojzek's Avatar
While you measure impedance of any inductor, Limp is supposed to show the value of a reactive component, and that is its inductance. At least, I remember Limp doing that while I was trying out stuff years ago.
Old 21st July 2021, 06:02 PM   #5
diyiggy's Avatar
When i mesure a voice coil and i click on RLC he gives the inductance in the highs frequencies only but don t give me any inductance for the voice coil. I measured... a 4 h and just have a ohm value related to the frequency.
Old 21st July 2021, 09:20 PM   #6
Lojzek's Avatar
That region of higher frequencies is the region of inductive reactance and this is exactly what you are trying to find, a voice coil inductance at certain frequency.
You can calculate yourself inductance value as long as you have Z(ohms) and phase angle (degrees) defined.
Xl=Z*sin(phase angle); Xl=inductive reactance
Xl=2*pi*f*L; pi=3.14159; f=frequency in Hz; L=inductance in Henries
Old 21st July 2021, 10:11 PM   #7
diyiggy's Avatar
Cool. LIMP is showing the phase.
Old 22nd July 2021, 12:36 AM   #8
trobbins's Avatar
I can indicate that the REW plot of impedance amplitude and phase allows the calculated inductive component to be read from the plotted curve (by placing the mouse pointer at the point you are interested in), and so the value will change with frequency (eg. approach DCR at low frequency), and will change to a capacitive value past the first resonance. REW also separately displays the equivalent model parameters, if valid. Often for comparison a particular frequency is typically chosen for certain part parameters like choke inductance (eg. 100Hz), or output transformer leakage inductance (eg. 1kHz), so the measurement frequency should really be stated when an inductance value is stated.
Old 23rd July 2021, 09:29 AM   #9
diyiggy's Avatar
Do you think one can use the Arta Box to plug the coil ?
I don't find in the menu jow to measure the coil.
Old 23rd July 2021, 04:58 PM   #10
Lojzek's Avatar
Any system designed to measure impedance of a loudspeaker, can measure impedance of an inductor, capacitor, resistor or a passive network, etc. You seem to struggle with something that is supposed to work simple.
Finding the inductance of a coil with a soundcard ?Hide this!Advertise here!
Thread Tools
Semi-Le_Calc: Calculator for Advanced Inductance Model Incorporating Semi-Inductance bolserst Subwoofers 85 12th January 2021 11:42 AM
Finding a low cost high accuracy method for measuring inductance/capacitance nannoo Equipment & Tools 13 18th February 2014 03:13 AM
Centre tapped coil with in a coil - inductance? peskywinnets Solid State 1 31st March 2010 05:13 PM
voice coil inductance VS transient response kan3 Multi-Way 12 9th February 2004 08:18 PM
Voice Coil Inductance (Le) and Transient Responce amo Multi-Way 11 8th June 2003 07:45 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
