Found a link you might find interesting.
Introduction to Python Serial Ports | PIC | Maker Pro
while(1):
# Wait until there is data waiting in the serial buffer
if(serialPort.in_waiting > 0):
# Read data out of the buffer until a carraige return / new line is found
serialString = serialPort.readline()
# Print the contents of the serial data
print(serialString.decode('Ascii'))
# Tell the device connected over the serial port that we recevied the data!
# The b at the beginning is used to indicate bytes!
serialPort.write(b"Thank you for sending data \r\n")
while(1):
No, standard IEEE double float semantics - Python shows 17 digits of precision,If you say so.
Python math (dodgy last digit rounding):
whereas double floats have about 16.5 digits precision. Nearly all computer languages use IEEE floating point numbers, so its not a Python-specific issue.
If you want more precision with a floating point number there are modules that can do it.
Basically there are Python modules for pretty much anything. Its extremely heavily used in science and data science with good reason.
Yes, I was half joking about pythons rounding and after >20 years in science technical support I am aware of how ubiquitous python is. Though MS Calculator gives me > 30 digits and it gets the rounding of the least significant digit right, so for on-the-fly paper calcs the basic python shell looses badly
Anyway, after having trawled through way more than what I should have needed to due to the generally crappy nature of python documentation (just my opinion) I have had my first proper script doing useful work for a couple of days now.
Is there a better (more elegant) way to prepare a mutable variable to make it work with ser.write than sticking it into an array?
Code:
# Set up RS-232 serial port
import serial
ser = serial.Serial()
ser.port = 'COM5' # Check port number (COM1, COM2, etc) in Device Manager and set accordingly.
ser.baudrate = 19200
ser.bytesize = 8
ser.parity = 'N'
ser.stopbits = 1
pixels=0
lines=0
address=0
data=0
f = open('640x480_24_bit_colour_image_02.bin', 'rb') # Open image file as a binary for reading
d = f.read() # Convert image file into a string
ser.open() # Open serial port
for lines in range(480):
while pixels < 640:
address = (lines * 1920) + (pixels * 3)
data = 0
# Read pixel data from binary
blue=(d[address])
green=(d[address+1])
red=(d[address+2])
# Convert 24-bit colour RGB to single-byte 6-bit colour
x = red&64 !=0
if x == 1:
data |= (1<<0)
x = red&128 !=0
if x == 1:
data |= (1<<1)
x = green&64 !=0
if x == 1:
data |= (1<<2)
x = green&128 !=0
if x == 1:
data |= (1<<3)
x = blue&64 !=0
if x == 1:
data |= (1<<4)
x = blue&128 !=0
if x == 1:
data |= (1<<5)
# Send pixel colour byte over serial port
element=[data]
a_var=bytearray(element)
ser.write(a_var[0:1])
print("Pixel=",pixels,"Line=",lines,"Address=",address,"Data=",data)
pixels += 1
else:
pixels = 0
ser.close()
Code:# Send pixel colour byte over serial port element=[data] a_var=bytearray(element) ser.write(a_var[0:1])
That can be reduced to:
Code:
variable=bytearray([data])
ser.write(variable[0:1])
Use a numpy byte array perhaps, as they implement the buffer protocol.
Code:
import numpy as np
length = ....
vec = np.zeros([length], btype = np.int8)
vec[..] = ... # write values into the array
with serial.Serial ("COM5", baudrate=19200, parity='N'. stopbits=1, bytesize=8) as port:
port.write (vec)
- Design & Build
- Software Tools
- Anyone here good at Python?
