85A2/0G3 LTspice model?
I don't have LTspice installed on this machine, but IIRC the "miscellaneous" folder contains a configurable neon bulb model.
You just need to specify the various parameters like strike voltage, resistance, hold current, etc.
This should be easy to extract from the characteristics of the regulator tubes (using a bit of common sense, obviously).
I will check tomorrow
Here it is, with the neon bulb crudely parametrized to look like an 0A2:
  • neontest.asc
