Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Transmission Line Modelling Software
Thread Tools
Old 29th May 2021, 04:27 AM   #931
perceval is offline perceval  Taiwan
perceval's Avatar
eesh... nevermind!
Instead of just dragging the folder to the trash and copying a new one, I used Windows own Uninstall in the control panel, and copied a fresh folder.
Got the app working again.
Sorry for the hiccup.
Old 5th June 2021, 09:47 AM   #932
Marveloudio is offline Marveloudio  Germany
Hello all , someone here stated some time ago that the LA software for TL design does not give correct results ... so I thought I let you know about another simulation software that has been confirmed to work correctly in dozens of real build and measured speakers , here the link to the website with free demo in german or english :
AJ-Systems - Loudspeaker simulation with AJHorn
Now in version v7 it does nearly any sort of bass loading , and low pass filter effects also accounted for , well worth the money!
have a nice time
Old 10th June 2021, 05:56 AM   #933
Mallickarjuna is offline Mallickarjuna  India
Mallickarjuna's Avatar
Send a message via MSN to Mallickarjuna Send a message via Yahoo to Mallickarjuna
Is the Leonard Audio-TL SW available to download?
Look like the link Nymeria doesn't work
Let's be on the same wavelength to understand each other
Old 11th June 2021, 07:38 AM   #934
David McBean is offline David McBean  Australia
The author confirmed in the post linked below that the tapped horn results were not correct, but as far as I am aware the others should be okay - they appear to be consistent with those of Hornresp.
www.hornresp.net
Old 19th June 2021, 03:56 AM   #935
What is the density of polyester fiber filling for specific GSM which are available from 100 GSM - 1700 GSM and which one to use as per the HornRes
  Reply to this post
Transmission Line Modelling SoftwareHide this!Advertise here!
Thread Tools
TLwrx v 3.0 Transmission Line Software CarlosT Subwoofers 16 27th March 2008 04:25 PM
3 Way Crossover modelling Software? Grahame Multi-Way 3 13th May 2007 04:50 AM
Matlab-based triode modelling software Radames Tubes / Valves 1 16th September 2005 07:36 PM
3d modelling software greg_mcquaid Multi-Way 17 22nd May 2004 07:03 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
