Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Transmission Line Modelling Software
Old 17th August 2017, 08:25 AM   #801
robotc is offline robotc  Australia
The leonard audio web site and software appears to be available in the web archive at
Wayback Machine.
If you click the date, May 16, 2017, it brings up the home page with a link to the software download. I went as far as the download window but I didn't go any further in case it messed up the version I have installed.
This might be an easier option to get the program
Old 17th August 2017, 01:43 PM   #802
3ll3d00d is offline 3ll3d00d  United Kingdom
3ll3d00d's Avatar
The setup.exe downloads additional files from the leonardaudio site so the wayback machine is not sufficient.
Old 17th August 2017, 09:49 PM   #803
3ll3d00d's Avatar
I hope the original author doesn't mind but I've made an offline installer by resigning his files (as per How to: Re-sign Application and Deployment Manifests with a test certificate as per Create your own .pfx file for ClickOnce – .net ready !!!) and then resaving the manifests using the mage.exe tool (part of the windows SDK tools)
the zip must be extracted to C:\tline_installer otherwise it won't work, i.e. you will have c:\tline_installer\TransmissionLine.application and then a subdir named AF which has the other files in it. Double click the application file and it should install normally without needing any webserver or external site.
Old 19th August 2017, 08:39 AM   #804
wae is offline wae  Netherlands
Thanks for the effort.
Still feels like we "need" to find out what happened with the official site and owner.
Looks a bit strange to me to just "disappear".
kind regards,
Frans
"If i ain't broken, DON'T fix it"
Old 22nd August 2017, 08:14 AM   #805
jazbo8 is offline jazbo8
diyAudio Moderator Emeritus
jazbo8's Avatar
Great, it installed fine. Thanks!
Old 24th August 2017, 04:57 PM   #806
BobtheBuilderMLG is offline BobtheBuilderMLG  United States
BobtheBuilderMLG's Avatar
Thanks for the zip. I would really like to know what happend to him. Its strange to say the least.
Old 24th August 2017, 05:51 PM   #807
diypass is offline diypass
installed perfectly.
does it download some files from internet during install ?
Old 24th August 2017, 11:46 PM   #808
opc is offline opc  Canada
opc's Avatar
Thank you very much for your effort on this! It worked perfectly for me, and I appreciate the work you put in!
Owen
Old 31st August 2017, 02:18 PM   #809
schmeet is offline schmeet  United Kingdom
schmeet's Avatar
Hey guys,
A bit of an update on this. I basically lost any free time I had to be able to develop this any further. I left it on the hosted website as long as I could but I decided not to renew the hosting subscription.
Don't worry about distributing it if you have the setup files. That's fine by me.
I'm keen to help it be available, so I'll have a look and see if I can find an alternative way to get it available again online.
Sorry for the lack of warning about it getting pulled from the internet...
Old 31st August 2017, 03:51 PM   #810
vinylkid58 is online now vinylkid58  Canada
vinylkid58's Avatar
Thanks for the update, and glad you're ok.
jeff
Transmission Line Modelling SoftwareHide this!Advertise here!
TLwrx v 3.0 Transmission Line Software CarlosT Subwoofers 16 27th March 2008 04:25 PM
3 Way Crossover modelling Software? Grahame Multi-Way 3 13th May 2007 04:50 AM
Matlab-based triode modelling software Radames Tubes / Valves 1 16th September 2005 07:36 PM
3d modelling software greg_mcquaid Multi-Way 17 22nd May 2004 07:03 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
