For those who would prefer to opt for the CineMag CMMI-15/15B over the more expensive Jensen JT-11P-1, the $38.26 price I gave in the Jensen thread is for 11-49 pieces. Since I could use another one, I'll buy the odd man out which means just 10 pieces for the group buy.
se
Interest shown for the CMMI-15/15B :
Dr. Strangelove3 : 2
Algar emi : 2
ble0t : 2
Steve Eddy : 2
Sy : 2
motherone : 2
Michi124 : 2
Andrew T : 6 (tentative)
Bas Horneman : 4
acliao : 2
pkpickard : 2
pekka : 2
jrd : 2
leadbelly : 2
jaap : 2
Total : 36
se
Algar emi : 2
ble0t : 2
Steve Eddy : 2
Sy : 2
motherone : 2
Michi124 : 2
Bas Horneman : 4
acliao : 2
pkpickard : 2
pekka : 2
jrd : 2
leadbelly : 2
jaap : 2
Total : 36
ble0t said:I'd rather do two of these since they're cheaper
No no. Read my lips. That's "less expensive."
BTW, is it necessary to add an op-amp gain stage onto the output side of the transformer? I've seen that in both the Cinemag and Jensen datasheets...is it just to lower the impedance?
No, there's no need for an opamp gain stage on the output. But it's going to have to be feeding some sort of high impedance input. How are you planning on using these?
se
I meant it in a monetary sense only
I was going to use them at the front end of my upcoming leach amp to allow for balanced input. I think pooge posted about some circuit modifications that would need to be made, but I can't remember where that post was...
ble0t said:I meant it in a monetary sense only
Well yeah, but "less expensive" is a monetary sense only too.
Ah, ok.
By the way, unless you already have a balanced output you want to feed it, keep in mind that with a good input transformer, common-mode noise rejection is very high whether you're feeding it from a balanced source or an unbalanced source.
In any case, you would just use the transformer directly with the amp's input without any intervening opamp circuit.
Can't help ya there, sorry.
se
Bas Horneman said:Put my name on for 2 as well please!
Howdy, Bas!
Will do.
Ok, we just need two more to get over the 11 piece hump.
se
By the way, is everybody ok with the 3/8" bushing mount version? That's the most rugged and versatile version in my opinion. But if somebody wants a different version, I'll ask David if I can mix types on the order.
Here's the datasheet showing the various options: CMLI-15/15B
se
se
Bas Horneman said:By the way ...Are these with single or double shielding/screen?
Single can. Same as the 11P-1.
se
Easiest to mount ...so that would be my choice as well.By the way, is everybody ok with the 3/8" bushing mount version?
Michi124 said:I'm in for two trannies as well.
(moving over from the Jensen group buy)
Thank you for this good suggestion!
Welcome aboard!
Well that gets us over the hump.
I'll go ahead and keep this going for the remainder of the week and the weekend and then start making arrangements next week.
se
SY said:Bushing is cool by me. Can we get racing stripes?
Why sure! Hell, I'll get you an 8-ball shift knob and a hood scoop too! Oh, and a "Jensens: Breakfast of CineMags" t-shirt.
se
- Group Buys
- Group Purchase for CineMag Input Transformers
