diyAudio
diyAudio (https://www.diyaudio.com/forums/index.php)
-   Parts (https://www.diyaudio.com/forums/parts/)
-   -   What are the sonic differences between various type of SMD resistors?? (https://www.diyaudio.com/forums/parts/360239-sonic-differences-various-type-smd-resistors.html)
escksu 16th September 2020 02:35 AM
I am wonder whats the differences in the sound we get from various types of SMD resistors.
Eg, I was told that foil resistors are the best, but they are also most expensive. We also have wire wound, thin and thick film resistors.
So, I am wondering if we are able to hear any differences in these resistors. Will a foil resistor sound very different from a thin film one??
Indiglo 16th September 2020 03:24 AM
There are no sonic differences. It's audiophile mythology.
Certain types of resistors will have specific applications depending upon material composition and physical properties. For example foil resistors are required where you need precision and temperature stability.
This is why manufacturers produce data sheets.
escksu 16th September 2020 04:17 AM
Quote:
Originally Posted by Indiglo (https://www.diyaudio.com/forums/parts/360239-sonic-differences-various-type-smd-resistors-post6342843.html#post6342843)
Ok thanks!
Yes, I do understand foil resistors have the best tolerance (0.01%) and best temp coefficient (0.2ppm/c)
But thinking about the tolerance... 0.01% at small values Eg. 10ohm resistor, 0.01% is 0.001 ohm. I am just wondering if it matters at in audio. Because we already get differences larger than that in many other components esp. power transistors and op amps. I doubt we can match these components to 0.01%
wintermute 16th September 2020 04:34 AM
I choose my resistors based on what the datasheet says about their noise and generally try for something in the 50-100ppm range. This is the one area where choosing a different resistor may make an audible (noise floor) difference IMO.
Recently I discovered Vishay MELF resistors https://au.mouser.com/Vishay/Passive...gsk8?P=1z0zls5 They tick all the right boxes (including being audiophile approved) except maybe price, but they are around the same price as the through hole Vishay CMF and RN series resistors I normally use.
As an added bonus they look cool :spin:
Tony.
JMFahey 16th September 2020 05:04 AM
Quote:
Originally Posted by escksu (https://www.diyaudio.com/forums/parts/360239-sonic-differences-various-type-smd-resistors-post6342815.html#post6342815)
Again trying to stir the pond with subjective opinion questions?
I wonder how long will this thread last until it turns into a mess.
Those who are sucked into this black hole, be warned :rolleyes:
DPH 16th September 2020 05:12 AM
The sonic difference between different SMD resistors comes down the the sizzle they make when you overload them. ;) Size appropriately.
But to answer your question honestly -- if you don't have a specific need where you know exactly why you're choosing a type of resistor composition, you'd do well to stick with metal films. (until at least you exceed their power range) I like susumu rg's.
SemperFi 16th September 2020 06:51 AM
Where do we place bets on the final length of this thread?
analog_sa 16th September 2020 10:17 AM
Quote:
Originally Posted by SemperFi (https://www.diyaudio.com/forums/parts/360239-sonic-differences-various-type-smd-resistors-post6342956.html#post6342956)
Hard to say as there are too little data points so far. To my embarrassment i still have not conducted any listening tests of smd resistors. It seems most of the better products use Melf, so those would be first on my list to compare to familiar tht resistors.
The uncertainty is generally discouraging me from using smd resistors, even though the absence of leads and caps seems like a good thing.
escksu 16th September 2020 10:42 AM
This message is hidden because JMFahey is on your ignore list.
sq225917 16th September 2020 12:24 PM
I like Vishay Melfs for cartridge loading in phono stages the nichrome parts used by goldpoint in the switched pots are also good.
Largely speaking though with smd parts theres no bad uns, unlike with through hole parts where all manner of noisy and none linear resistive elements exist.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
Wiki
