How about some information about whatsupernet said:Have anybody built project 88 from Rod`s page? I am interested in sound quality.
Supernet
ESP Project 88 is?
High Quality Audio Preamp (Mk II) - Rod Elliott (ESP)
------------------------------Introduction
The original preamp (Project 02) shown on these project pages is basically a good design, but in the interests of improved quality and reduced "frills" this new version will fill or exceed most expectations. The quality comes largely from the use of one of the nicest sounding opamps available, the Texas Instruments/ Burr Brown OPA2134.
Although a conventional voltage feedback device, this opamp has few peers for sound quality, and I decided that it was time to make a PCB available.
It is a control preamp based on Burr-Brown OPA2134 dual OP.
Uses one OP for input and a second OP for output.
In between are Balance and Volume control.
It uses input and output caps.
You can select the gain of OPamp to suit your needs.
There are tables for how to Set the Gains of the OPamps.
Suggested Power Supply is 2x15VDC.
Preliminary measurments, on the workbench:
Frequency Response 10 Hz to 250 kHz -0.4 dB
Noise < 0.5 mV RMS at full gain (input open)
Crosstalk Better than -58 dB at 100 kHz
Picture shows the Project 88; OPA2134 hifi pre amp
on the available PCB.
/halo
Yes, Perfect trwh !!!
Pics of my preamp - trwh
Maybe we can go over there to get some comments from
trwh
/halo
trwh
/halo
supernet said:Wov, nice project. Could you post the schematic of Alps control circuit?
Do you satisfied with it`s sound quality?
Hi supernet
I'm reluctant to post the schematic of the remote volume control circuit, since as I say in my other thread, I pinched it from a service manual!
The sound quality is excellent, I could easily compare the P3A/P88 combo to commercial gear in the $1k+ range.
See ya,
Tim.
See ya,
Tim.
That's allright Tim, you can mail it to me - I won't tell (seriously, if you think you can post it, I'm very interested as well)
/U.
Hi
I've had about a dozen requests for the schematic of the remote control circuit since I made my original post. I always have to decline, since:
a) The circuit isn't mine, it is from a commercial product, albeit an old one.
b) Even if I did give you the schematic you would need the PIC, which is hard (if not impossible) to get hold of.
I don't know why there isn't a readily available remote control kit for motorised pots out there - if someone were to make one, I'm sure there would be a lot of interest.
See ya,
Tim.
See ya,
Tim.
here is a pre with different op amps and no cap's, it's from the AA bellini pre, which receives good press.
http://www.pi.infn.it/~federico/bellini.htm
i built the one from the puccini (with caps) and was VERY pleased with the results with my p3a.
Mark
Mark
Re: Re: Rod Eliot project 88 question
As rode - Rod Elliot has joined as one member by many at this site,
I'd like to say a welcome, afterwards.
The circumstances could have been better at his arrival.
The number of newbies, who has, through him, gotten a fair introduction
to the hobby of Audio Electronics, can be counted in 1000s
if not 100.000s.
There is often some stuff at his site we can refer and link to,
when somebody asks question, or want a circuit to build.
And so has halojoy done on many occations, for sure.
As I am not know for caressing ANY authority unnessesarely,
I say:
Welcome, but don't expect any other favours,
than ordinary members or Nelson Pass gets.
I will try to superwise that the moderators
keeps everything fair and square.
halojoy has one time said:
The higher you sit, the harder you hit
the ground at your fall
In this thread we find a good example of what can be built
inspired by "Aussie-Rod":
"Project 88; OPA2134 hifi pre amp"
and in this thread with GREAT PICTURES
http://www.diyaudio.com/forums/showthread.php?s=&threadid=9228
we see how it can combined with
"A double barrelled Elliott P3A Power Amp"
All these "great men" seems to be very busy
but I hope you can contribute every now and then, Rod.
Who would be more suited to comment on your projects?
halojoy - thinks rode's site is like "having circuits in the bank"
ESP Project 88 is?
/halo
if not 100.000s.
I say:
let's bring this thread back to life. i know tons of people know the esp site and recommend reading the articles on it. yet i barely find any information on people building the projects. i read through project 88 and it seems like a fine preamp. yet the last entry in this thread is from 2003 - holy cow, that's 15 years ago.
what's the current opinion on this preamp design?
P88
I have built two p88 preamps on strip-board. Very simple opamp implementation that sounds totally clear and provides volume and balance controls. I have tried several opamps including OPA2134, TL072, 4558, 4560, 4580, LM833, 2068, 5532, and MC33078. All except OPA2134 and TL072 have volume pot noise. Some are extremely noisey with low frequency (DC) effects and visible speaker cone excursion when turning the volume pot. Definitely needs a capacitor between the balance and volume pots if using bjt opamps. I can't hear any difference between OPA2134 abd TL072, both sound great. Just my $.02
- Analog Line Level
- Rod Elliot Project 88 question
