Salas,
I have a couple of 'generic digital' power supply bases with 9 rails on each. 4 of these rails are the DAC and digital processing (isolators, reclockers, etc) supplies. On this base, those supplies are based on 2 Hammond 220D16 transformers, with one secondary used per supply. The secondary feeds a diode bridge of DSEP30-06A diodes (overkill, but in my experience good sounding) and the output C of each supply is a Jensen 47000/25V 4-pole capacitor. I also include a John Swenson transformer-ringing suppression snubber on each secondary (more info on that here: Good linear PSU(s) for CAPS music player that won't break the bank - Page 12 - Music Servers - Audiophile Style ).
All of these come together at a 16-pin Hirose connector which allows me to plug and play various digital sources.
Each 'base' also has a supply with a 5V and a 3.3V rail for a source (RaspberryPi, SDCard player, or similar), a lightly-filtered quick-drop-out supply for an on-off mute relay, and an output stage supply with a +-21V output where needed.
For the Allo.com Katana, I use just 2 of the DAC/digital processing rails. Sonics are slightly better if I use one rail from each transformer.
Greg in Mississippi
P.S. These bases are built onto a large bamboo cutting board which also acts as the siting platform for the digital source in use. My other base like this uses some discontinued Amveco toriod transformers instead of the Hammonds. At some point I need to compare sonics between the 2 versions.
Greg in Mississippi
Thanks, I used 14 AWG stranded. Any bigger and it was going to be tough getting them in placeNice arrangement and thick cables
I have bought this one for the Vaio
Ultra Low Noise linear power supply LPS PSU KIT 5V 9V 12V 15V 18V 24V L163-73 | eBay
- Power Supplies
- Reflektor-D builds
