Reflektor-D builds
Reflektor-D builds
Old 19th January 2017, 12:02 PM   #1001
TioFrancotirador is offline TioFrancotirador  Poland
Originally Posted by samoloko View Post
thank you for reply
I ve read It but It Is meant for digital
can we lower C2 value to 470 uF If we use to supply analogue loads
My subjective best choice for analog was useing Mundorf 4pin AG+ 1000uf cap. In the post I described how to connect it. For digital I used Nichicon FPCAP 1000uf.
I experiment with lowering the value of C2 down to 100uf and using polypropylene cap, however results were not satisfactory for me.
Old 19th January 2017, 03:38 PM   #1002
merlin el mago is offline merlin el mago  Europe
merlin el mago's Avatar
Salas could I use 12VAC 4A transformer?
Old 19th January 2017, 09:58 PM   #1003
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Reflektor-D builds
Yes if your CCS sink does not get too hot
Old 23rd January 2017, 02:55 PM   #1004
wyan is offline wyan
Reflektor-D builds
Has any one tried 2SK880GR instead of 117GR? Any difference in performance? Thanks.
Old 23rd January 2017, 03:23 PM   #1005
selfy is offline selfy  Bulgaria
selfy's Avatar
I tried 2SK880-GR but in BiB. They are OK performance-wise and I did not notice any sound degradation. If you are wondering just go for them
"Music is enough for a lifetime, but a lifetime is not enough for music" Rachmaninoff
Old 23rd January 2017, 03:40 PM   #1006
Reflektor-D builds
Thanks. I will buy some and try.
Old 25th January 2017, 05:57 AM   #1007
Reflektor-D builds
Hi, Tio
I am thinking to use Mundorf Mlytic AG+ in C2.
I suppose in your connection, you lift the LEDs off ground by employing Mylytic's separate charging / discharging circuit (kind of decoupling). However, it looks like we should use in+ and in- to form a loop and then out+ and out- to form the other (decoupled) loop. Your connection seems to be different than Mundorf's description and than the connection on Salas' flexy. Could you double check?
Mundorf MLytic AG+ 4-Pole cap users : beware of wiring, some of us got it wrong ! | Audiokarma Home Audio Stereo Discussion Forums
Thanks.
WYAN
Originally Posted by TioFrancotirador View Post
Try also Mundorf 4 pin Ag+ caps. They are excellent. Especially on C2 (1000uf) position . Among many caps I tried here (elna silmic II, black gate Std, Elna Silmic ARS, Nichicon FPCAP, Nichicon muse BP non polar ...) Mundorf 4 pin are of the widest audio bandwidth (especially high frequencies are very clear and deep bass), best resolution and clarity. You connect your LEDs between Out(-) and In(+) pins then In(-) to GND in PCB and Out(+) to PCB + trace. You would have to just modify/destroy your board in good way to fit this cap or you could wait until Salas releases Reflector-D Mini Flexy version, some day, maybe . Anyways it is really worth mod.
And as you already mentioned give some time to burn in.
So, for digital part of chips (DVDDs) I am using Nichicon FPCAP on C2 position (best 1/f filtering, but terrible tone). However for AVDDs, analog Vrefs or powering resistor ladders dac directly (Soekris R2R), generally places from where audio signal is produced from, Mundorf 4 pin I found to excel any other cap in this position.
Old 25th January 2017, 08:13 AM   #1008
Originally Posted by wyan View Post
Hi, Tio
Thanks.
WYAN
The description you provide is for case when 4pin cap is used in PSU application.
The one I described is for LEDs filtering. It is tested and works. I got few reflectors working like that. I cannot imagine connect it any other way for LEDs.
Old 25th January 2017, 11:31 AM   #1009
Does anyone have spare regular (not mini) Salas Reflector D board to sell? Please PM me if so.
Old 25th January 2017, 11:50 AM   #1010
Reflektor-D builds
Thanks. Scratching my head and trying to figure out ...
Reflektor-D buildsHide this!Advertise here!
GB for Salas Reflektor-D Power Supply for Digital Tea-Bag Group Buys 419 9th February 2020 12:22 PM
NOS Russian Reflektor 6P6S (6V6) tubes were a pleasant surprise KrankKall Tubes / Valves 7 26th February 2014 08:07 PM
Some VX.2 Builds CSS/XBL CSS 0 11th April 2013 06:34 PM
FS 8X 6P3S Reflektor Valves NOS Tbird Swap Meet 9 6th June 2011 04:18 PM
so who here builds amps amp builder jb Tubes / Valves 29 15th July 2005 09:23 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
