I have a ML ReQuest crossover which allegedly was hit by lightning. A lot of semis on the high voltage sensing board were destroyed. I have replaced these but the board still does not work. It powers up the HT for a while at startup and then cuts off. Feeding signal does not retrigger it like it should. The board is shown only as a block in the crossover schematic. Does anyone have a schematic?. ML tech support is a dead letter box.
Cheers
Mike
Cheers
Mike
Can you post a pic of the board?
Based on the ML museum timeline, it is likely one of the MLPS10x series of boards.
If so, circuit should be very similar to attached.
NOTE: If your Request is an import from a country with 60Hz mains, you may need to bypass the frequency sense portion of the circuit. See post here: ML Aerius import from USA
Thanks so much - this contained everything I needed to get things ticking again.Can you post a pic of the board?
Yeee-hah!
Cheers
M
Once I bypassed the frequency sense circuit, it worked like a bought one.Well that was quick!
What did you determine had gone wrong?
What a strange bit of engineering - to include something to prevent operation
on 50Hz mains (but allow it on 60Hz).
Thanks for your help.
M
- Planars & Exotics
- Martin Logan ReQuest query
