Martin Logan ReQuest query
I have a ML ReQuest crossover which allegedly was hit by lightning. A lot of semis on the high voltage sensing board were destroyed. I have replaced these but the board still does not work. It powers up the HT for a while at startup and then cuts off. Feeding signal does not retrigger it like it should. The board is shown only as a block in the crossover schematic. Does anyone have a schematic?. ML tech support is a dead letter box.
Cheers
Mike
Can you post a pic of the board?
Based on the ML museum timeline, it is likely one of the MLPS10x series of boards.
If so, circuit should be very similar to attached.
NOTE: If your Request is an import from a country with 60Hz mains, you may need to bypass the frequency sense portion of the circuit. See post here: ML Aerius import from USA
Thanks so much - this contained everything I needed to get things ticking again.
Yeee-hah!
Cheers
M
Excellent! :up:
I just included that note about 50Hz/60hz as an afterthought...glad I did.
I seem to recall reading in Stereophile that ML was included country specific power supplies to help their foreign distributors cope with grey market sales.
Thanks guys for sharing such useful information.
As a matter of interest, have you noticed that the speaker binding posts polarity is reversed on the ReQuests?!
The +/- posts connected to -/+ internally ???!!!
