PC Based Computer music servers, crossovers, and equalization
Moode Audio Player for Raspberry Pi
Old 30th October 2016, 04:43 PM   #5061
sandy053 is offline sandy053
Originally Posted by TimCurtis View Post
Refer to post below.
-Tim
Did not find a similar topic. Wanted to report the problem.
Old 30th October 2016, 06:19 PM   #5062
sdsi is offline sdsi
Thanks a lot for your job with MoOde Player!
Please - let me know the answer: how can I use own web radio streaming URL?
My URL don't work at all. Work with Volumio software - don't work with MoOde. Example:
PolskaStacja Smooth Jazz -http://www.polskastacja.pl/play/smoothjazz.pls
Polskie Radio Dwˇjka http://stream3.polskieradio.pl:8902/listen.pls
How can I solve this? Thanks.
Best regards,
Old 30th October 2016, 07:12 PM   #5063
TimCurtis is offline TimCurtis  United States
TimCurtis's Avatar
Best regards,
Moode requires the direct stream url. This is the url assigned to the File1= param inside the pls file.
-Tim
Old 30th October 2016, 08:25 PM   #5064
@TimCurtis - I see; thanks a lot
Old 30th October 2016, 11:06 PM   #5065
Zootalaws is offline Zootalaws  New Zealand
Sometime in November barring any unforeseen circumstances.
-Tim
Zombie apocalypse? Meteor? Trump?
Old 31st October 2016, 08:40 AM   #5066
philrandal is offline philrandal  United Kingdom
-Tim
It would be great if Moode were enhanced to "do the right thing " with .pls stream definitions. And cope with changing contents of the pls files.
Pi Zero W + Pimoroni pHAT DAC / Pro-ject Elemental / Marantz CD6004 / Marantz PM6004 / Monitor Audio Bronze 2
Old 31st October 2016, 02:46 PM   #5067
TimCurtis's Avatar
Alien abduction.
Old 31st October 2016, 03:39 PM   #5068
Ah... probed. I see...
Old 1st November 2016, 11:30 AM   #5069
jonwhitear is offline jonwhitear  Australia
Originally Posted by jonwhitear View Post
Tim, Fair enough - I shall ask them. Out of interest, what's the impact of selecting different I2S devices? Presumably the raspberry PI I2S pins are always the same, so is this just a means of selecting different device capabilties such as hardware volume control?
Jon
Tim, it turns out the Buffalo expects 32 bit input on i2s. I've configured MPD to resample to 32 bit and it works. Do you know if I can also force airplay streams to resample?
Cheers, Jon
Old 1st November 2016, 12:10 PM   #5070
TimCurtis's Avatar
Cheers, Jon
Hi Jon,
Airplay receiver outputs fixed 16/44.1 however in Moode 3.0, the Advanced Kernel supports simple-bclk-64fs setting for ES9018 and PCM1794 based DAC's so in theory Airplay output should work.
Send me email and i can get you a Moode 3.0 test image to try out :-)
-Tim
Moode Audio Player for Raspberry PiHide this!Advertise here!
My DAC for the Raspberry Pi usul27 Digital Line Level 157 16th July 2020 12:17 PM
Raspberry Pi + CirrusLogic Audio Card = FAIL solderhead PC Based 32 23rd June 2020 04:24 PM
DSP for the Raspberry Pi usul27 Digital Line Level 39 30th August 2016 07:29 AM
RaspyFi/Volumio - Turn raspberry Pi into Audiophile audio Player mikelangeloz PC Based 295 14th June 2014 05:32 PM
miniAMP and raspberry pi kp93300 miniDSP 0 3rd March 2014 03:38 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
