LuDEF
Have you tried going direct into the VAS traffo? Works great with the ACP+, also the Iron Pumpkin. I wired mine up with a switch, but it mostly just stays in bypass mode now.
Have you tried going direct into the VAS traffo? Works great with the ACP+ & also the Iron Pumpkin. I wired mine up with a switch, but it mostly just stays in bypass mode now.
No, actually I haven't tried much yet - can't stop listening to it long enough, to experiment :rofl:
Driving the transformer directly from the preamp through the signal wires, haven't thought about that - I would propably rather go in the direction of a "stronger" input buffer instead.
I do have Tombos input buffer PCBs in the drawer to try.
So many things to try 😁 but first music
Reactions: Dan K
