While they last...
While they last...
Thread Tools
Old 23rd November 2021, 11:25 PM   #1041
Soundhappy is offline Soundhappy  France
Soundhappy's Avatar
@ Diyers
Ok at 1 Watt get nice distortion 2 harmonic profile many amp's can show similar figures
but at 20 or 50 Watts distortion rise super fast and % is much higher with Tokin's.
Again maybe from J Broskie article or from MEPER post # While they last...
Sakuma style solution..or new Mr. Pass ?
Can be interesting to learn and experiment.
Use LTSpice first so no danger of smell the smoke
class A amplifiers with full range speakers
sings like angels in heaven
Old 23rd November 2021, 11:33 PM   #1042
Ben Mah is offline Ben Mah  Canada
While they last...
Mu follower common drain THF-51S at onset of clipping (50W into 8 Ohm), left and right channels. Two percent THD is quite good and probably no worse than VFETs, except VFET can't output 50W.
20W added.
Old 24th November 2021, 05:21 AM   #1043
Adams_Leo is offline Adams_Leo  China
WOW,fantastic.
My plan DN2540 buffer and then KP926 driver 2SK182/THF-51S follower with chock load.I am waiting for the chassis.
Also I am consider ZM's buffer.
Old 24th November 2021, 11:01 AM   #1044
triode_al is offline triode_al  Netherlands
triode_al's Avatar
Originally Posted by Soundhappy View Post
@ Diyers
Ok at 1 Watt get nice distortion 2 harmonic profile many amp's can show similar figures. . .
here my experimental set for the source followers
Various feedback, also the famous F6-style feedback.
The transformer is modelled so-so, could be improved
la recherche d'un son perdu
Old 24th November 2021, 11:26 AM   #1045
stonegreen is offline stonegreen  Germany
Default missing symbol 'xnjf'
Thanks for the experimental set, but there is a problem with loading.
Old 24th November 2021, 02:52 PM   #1046
Botte is offline Botte  United States
Botte's Avatar
While they last...
Hi Ben,
I have similar results. I did increase the bias to 2.6 amps and it increased the 4 ohm power but it didnt sound better. It also increased the heat dissipation so, I cut it back to 2.2 amps.
File Type: jpeg FF0D7611-FDD4-4B87-BC60-6450F035FA93.jpeg (579.5 KB, 214 views)
Old 24th November 2021, 05:17 PM   #1047
I replaced the missing symbol with an 'njf' and set the prefix to 'X'. Now everything is OK.
Old 25th November 2021, 11:18 AM   #1048
triode_al's Avatar
here they are
XNJF.asy looks as follows (cant upload the symbol)
Version 4
SymbolType CELL
LINE Normal 16 16 16 80
LINE Normal 48 72 48 96
LINE Normal 16 72 48 72
LINE Normal 48 24 48 0
LINE Normal 16 24 48 24
LINE Normal 0 64 4 64
LINE Normal 4 68 16 64
LINE Normal 4 60 16 64
LINE Normal 4 60 4 68
WINDOW 0 56 32 Left 2
WINDOW 3 56 72 Left 2
SYMATTR Value NJF
SYMATTR Prefix X
SYMATTR Description N-Channel JFET
PIN 48 0 LEFT 5
PINATTR PinName D
PINATTR SpiceOrder 1
PIN 0 64 TOP 5
PINATTR PinName G
PINATTR SpiceOrder 2
PIN 48 96 LEFT 5
PINATTR PinName S
PINATTR SpiceOrder 3
Place it with a text editor where the LTSpice can find it. I have it high on the file structure, but it really should be where other ASY's are.
File Type: txt xnjf.asy.txt (539 Bytes, 3 views)
Old 25th November 2021, 12:01 PM   #1049
triode_al's Avatar
For some more fun (but this thread is not for that ; sorry S.)
drain loaded
  Reply to this post
While they last...Hide this!Advertise here!
Thread Tools
Last plea for a while: 1x8" or 2x6.5" SB woofers for a two-way? Apfelsauce Multi-Way 3 29th April 2011 06:20 PM
new dipole baffle...last one for a while ultrachrome Multi-Way 1 7th September 2005 09:13 AM
Maplin "While Stock Last" AP130M0 4.98 Beggar Multi-Way 0 7th July 2004 10:59 AM
2SJ56-2SK176 on ebay in quantities! get'im while they last! KBK Parts 4 15th February 2004 08:16 AM
Last post for a while, featuring non-audio gratuitous image Jocko Homo Everything Else 11 5th November 2002 05:04 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
