F5 Ground Loop hum help please
Thread Tools
Old 12th January 2021, 06:08 PM   #41
rhthatcher is offline rhthatcher  United States
There are 2 ground holes betweeen the caps at the opposite end of the input from rectifiers. Put one leg of the cl60 there. Other leg to chassis.
Here is an example from one of 6L6ís build guides
File Type: jpeg 413CBAB0-F30D-4DD9-91B8-24DCBD8F7319.jpeg (292.3 KB, 83 views)
Old 12th January 2021, 09:21 PM   #42
rtate is offline rtate  Canada
Thanks, that's exactly what I needed
Old 13th January 2021, 07:59 PM   #43
McQuaide is offline McQuaide  United States
I'm using shielded twisted pair on the inputs with the shield grounded to the RCA jack ground. Runs nice and quiet.
Mark Micro Seiki DDX-1000>Pearl 2>BA-3 FE>F5>Mirage OM-7 Towers
Old 14th January 2021, 01:10 AM   #44
Maybe I will try that too !
easy enough to try !
  Reply to this post
F5 Ground Loop hum help pleaseHide this!Advertise here!
Thread Tools
Vintage Harman Kardon amp ground loop issues - 2 prong plug w/floating ground ThatDavid Solid State 16 22nd February 2019 09:04 AM
Need help with 60hz hum/ground loop. Schematic attached. Fusion916 Solid State 32 11th October 2012 09:25 PM
hum,ground loop,earth loop problem with your answers please frank2395 Pass Labs 2 17th May 2005 07:46 PM
does connecting mains ground with circuit ground create a ground loop? jarthel Everything Else 0 25th June 2003 01:55 PM
Ground loop hum jag Pass Labs 20 25th November 2002 06:32 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
