Beast with 1000 JFETs redux ?
Thread Tools
Old 21st January 2021, 10:09 PM   #181
woofertester is offline woofertester  United States
Thank you Biosonar for that info. It helps enormously.
I have thought that the J113/J175 version should have source resistors for power dissipation reduction. Now I will start a PCB for that configuration.
While we are talking about the J113, my datasheet shows gate at the left-most pin. The actual JFET has gate at the right-most pin. What is the deal with that?
For Idss, my J113 devices are all between 14mA and 28mA. I have tested hundreds. I bought a bag of 1000. Slowly working my way through them.
My J175 devices are between 20mA and 24mA. I have tested 100. More are on the way.
My assertion is that the combined Idss of each 1/2 of the buffer must match. The parallel buffer elements are all connected at the output.
So, there will be a PCB for un-degenerated FJETs like the J270 and 2SK304. That pcb is on the way to me. There will be a pcb for degenerated JFETs like the J113 and J175.
Old 22nd January 2021, 12:00 AM   #182
Biosonar is offline Biosonar  United States
Here is another possibility for CCS mini-beast using the Toshiba 2Sk209 GB jfet. This design was suggested by Wayne from Pass Labs. Remove R4, R5 and add a gate resistor to the input:
File Type: jpg 59F4A268-D316-48C0-9FAD-D2F45B08B726.jpg (1.05 MB, 330 views)
Old 22nd January 2021, 12:20 AM   #183
I agree that a 2SK209/2SK208/2SK2145 massive B1 is a great idea. The trough-hole version is first on my list to build. The surface mount version for me will have to be assembled at a contract manufacturer.
Rochester has good candidates for through-hole JFETs. I have ordered some to evaluate. I will also build J113/J175 through-hole versions.
Old 22nd January 2021, 03:59 PM   #184
After new information from Biosonar, I have changed the basic cell. Here is the schematic.
I have added G-D-S transistors. The original transistors are D-G-S. Now the builder can choose D-G-S devices or G-D-S transistors. You can choose one of each.
The J113 is D-S-G and the J175 is D-G-S. These two can be used with this new board.
Old 22nd January 2021, 05:11 PM   #185
Here is the PCB.
Old 23rd January 2021, 08:45 PM   #186
Default B1 Mini Beast
Both D-G-S and G-D-S pinouts are supported on this Mini B1 Beast
I am sorting the JFETs I have and have ordered additional types to characterize.
You can also use all P-JFETs if you reverse the power supply polarities. Aye, Keptin. Reverse the polarities.
Old 23rd January 2021, 08:52 PM   #187
mhenschel is offline mhenschel  Canada
Sounds like "reworse".
Old 24th January 2021, 11:14 PM   #188
Default Series B1 for extended voltage?
I have found a surplus JFET that is reasonably priced and has good gm and low noise. The limiting factor is that the device max voltage is 15v. If I want to use + / - 15v rails, is this a reasonable approach for the basic cell?
Old 25th January 2021, 12:04 AM   #189
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
well, not exactly
when you put more than one CCS in chain, there goes trouble
go here and download some reading material: Erno Borbely site , zip file - for benefit of DIY community - Zen Mod Blog
cascode them with bjts, shown in numerous Papa's thingies, same as in SissySIT etc.
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 25th January 2021, 01:21 AM   #190
Originally Posted by Zen Mod View Post
well, not exactly
Ok Thanks. Will do.
Beast with 1000 JFETs redux ?Hide this!Advertise here!
Thread Tools
tube x-over noise redux jlg4104 Tubes / Valves 4 12th December 2020 01:31 AM
Article: Beast With a Thousand Jfets Nelson Pass Pass Labs 126 18th September 2019 09:35 PM
The Beast with a Dozen Jfets wrenchone Pass Labs 30 24th June 2013 04:31 AM
Beast with a Thousand JFETs Nelson Pass Pass Labs 297 18th May 2013 12:38 PM
Guidelines for switching N-channel JFETs to P-channel JFETs (and vica versa)? Test Electrix Construction Tips 9 24th January 2011 07:22 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
