F4 board ID
I'm pretty sure this is a First Watt clone but have no idea which one.
Help appreciated!
Thanks,
Sam
Peter posted a BOM in post #631 here:
https://www.diyaudio.com/forums/gro...e-pcb-reissue-buy-f5-pcbs-64.html#post1737890
Note this is for a slightly older version of the schematics. The current
version (as shown in the F4 manual 6L6 linked above) contains
some value changes. The ones I spotted are:
R3, R4: From 22.1R to 10R
R8: From 22.1K to 27.4K
R10 to R15: From 100R to 150R
The boards are fine but the resistor spacing is pretty tight. For the
non-power resistors you might consider more compact/shorter ones.
These boards haven't been available for a while so you're less likely to
find recent experience with them, compared to the store boards.
Dennis
That's funny, I'm just getting back into class A ss stuff after quite a few years and I too found a set of Peter Daniel's F4 boards. I'm pretty sure the ones I found are labeled 'Audio Sector' though. I'm interested in building an F4, but planned on buying the boards from the store to avoid any unnecessary hassle.
