At the price to build a FW clone I would not try and save money by not buying store F4 boards. You will get an abundant supply of info building from store boards.
Peter posted a BOM in post #631 here:
https://www.diyaudio.com/forums/gro...e-pcb-reissue-buy-f5-pcbs-64.html#post1737890
Note this is for a slightly older version of the schematics. The current
version (as shown in the F4 manual 6L6 linked above) contains
some value changes. The ones I spotted are:
R3, R4: From 22.1R to 10R
R8: From 22.1K to 27.4K
R10 to R15: From 100R to 150R
The boards are fine but the resistor spacing is pretty tight. For the
non-power resistors you might consider more compact/shorter ones.
These boards haven't been available for a while so you're less likely to
find recent experience with them, compared to the store boards.
Dennis
Dennis
That's funny, I'm just getting back into class A ss stuff after quite a few years and I too found a set of Peter Daniel's F4 boards. I'm pretty sure the ones I found are labeled 'Audio Sector' though. I'm interested in building an F4, but planned on buying the boards from the store to avoid any unnecessary hassle.
Believe I have the printed BOM somewhere in case it's gone.
Discovered this boards recently as well
Audio Sector was (is?) the name of Peter's business.
It would be a pity if he wasn't active anymore. I admired his designs a lot, they're great.
The audio sector board is quite nice and works well. If you have them, use it!
And deny ourselves your build guide?
Thanks for the info everyone.
I'm forging ahead with Peters boards. Fingers (and toes) crossed. 🙂
- F4 board ID
