Threshold S500 II volume  issue.
Old 12th January 2020, 01:53 PM   #11
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
yup
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 12th January 2020, 05:05 PM   #12
Silvanik is offline Silvanik  Italy
Originally Posted by mpmarino View Post
The S/500 I purchased had low or no gain in one channel.
Of course I knew the electro caps were past their life, and that the
tantalums were risky.
When I replaced the 420uf (470?) electro cap the gain was back. Subsequent testing of the old cap showed it was dead. The 420uf (470?) on the still working channel tested OK. (replaced anyway of course). Then replaced the tants with film.
I would start there, get it working and then worry about the bias - Unless it's too high right now!
Mpmarino, thank you so much for your valuable hint, it seems that I have similar issue, as soon as possible I'll check those damn tantalums with the hope this fix the issue. My serial number says that my S500 II was built in 1986 so can't actually complain if sometingh start to show its age.
Luckly I'm able to replace them on my own, any suggestion about the best replacement I can use for these caps?
Old 12th January 2020, 05:29 PM   #13
MEPER is offline MEPER  Denmark
MEPER's Avatar
I read the above as it was the 420/470 uF e-cap that was the real problem so you should probably re-cap both types (e-caps and tantalums) so be sure amp will run without problems for the years to come…….
Old 12th January 2020, 05:50 PM   #14
You are perfectly right! I'm going to replace all the capacitors present in my amp with the best I can find, I want make it really sings as it was designed for.
A part this functional issue the amp looks like new, (thirty four years old now!) cosmetically speaking.
I replaced all the original flimsy feet with more suitable and stronger rubber ones, considering its weight it had to be the oem choice even because the mechanical and electrical construction is top notch.
Old 14th January 2020, 10:18 PM   #15
Mpmarino, just checked my caps, tantalums and some e-caps found dead!
Now I'm in the process to find the best caps on the market to replace them and bring back my S500 to life.
Can't wait for this work done and compare the Threshold to my other amp McCormack DNA-2 driving one of more bastard load you can meet, the Thiel CS 3.6 speakers, thing that the DNA-2 actually does with pleasant authority.
Old 15th January 2020, 01:17 PM   #16
mpmarino is offline mpmarino  United States
mpmarino's Avatar
I hope it fixes your issues. I think it will.
If it doesn't, it needed doing anyway
Crazy Yankee.
Threshold S500 II volume  issue.Hide this!Advertise here!
Touch up heatsink on Threshold S500 Mikerodrig27 Pass Labs 10 13th January 2020 12:57 PM
Threshold ll S500 optical Bias Jenis Pass Labs 5 16th January 2019 08:09 AM
Replacement rectifier bridge for Threshold S500 eswaroop Pass Labs 7 25th February 2018 01:14 PM
Threshold Stasis S500 Series II amandarae Pass Labs 9 21st November 2009 06:39 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
