How do you measure bias with no source resistors?
Old 14th November 2019, 02:10 AM   #11
woody is offline woody
What's up with r 25,26,27 & 28 ? It looks like you have them shorted out ?
Old 14th November 2019, 11:28 AM   #12
JeffYoung is offline JeffYoung  Ireland
JeffYoung's Avatar
@woody, no, it's just poorly drawn because I never cleaned it up after playing with a few different ideas. The resistors are in parallel.
(I've also discovered that I can't find any metal films in 4W either, so they need doubling up again -- at which point there's not much point in showing them that way in SPICE.)
Here's a clearer version:
How do you measure bias with no source resistors?-jamjar-jpg
Old 14th November 2019, 12:40 PM   #13
JeffYoung's Avatar
Originally Posted by Mark Johnson View Post
Consider the Hantek CC65 from eBay. I have one and I am pleased with the results I get from it.
I can certainly imagine other instances where being able to view the waveform would be very useful (such as determining the class A envelope -- assuming the output devices are on flying leads).
I did some Googling and Pico also sells one[1]. Looks like it was made in the same factory, but with slightly higher-spec parts (at least there's a strain relief on the cable, and a metal latch ring on the BNC). A bit more dosh, but maybe better quality control too?
Thanks for the idea, Mark!
Jeff.
[1] https://ie.farnell.com/pico-technolo...ope/dp/2677035
Old 14th November 2019, 01:27 PM   #14
indra1 is offline indra1  Indonesia
I'm not so sure on the how but new current clamps such as HoldPeak HP-870K shows DC current range.
Old 14th November 2019, 02:48 PM   #15
Mark Johnson is offline Mark Johnson  United States
diyAudio Donor
Mark Johnson's Avatar
Here's another use I found for the cheapo Hantek current probe: visualizing and measuring inrush current when the AC mains is switched on.
_
Old 14th November 2019, 03:27 PM   #16
woofertester is online now woofertester  United States
DC current transformer.
Old 14th November 2019, 03:55 PM   #17
synonymous is offline synonymous  United States
Send a message via MSN to synonymous
Voltage drop across Q11?
Old 14th November 2019, 04:59 PM   #18
JeffYoung's Avatar
To do it based on voltage drop across Q11 wouldn't you need to know what the transfer curve looked like at the rail voltage? (The datasheet only contains curves at 10Vds.)
Old 14th November 2019, 06:40 PM   #19
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
I just put a .1 ohm resistor in series with each Drain/Collector. Works fine.
Old 14th November 2019, 09:27 PM   #20
GKTAUDIO is offline GKTAUDIO  United States
GKTAUDIO's Avatar
Like this?
How do you measure bias with no source resistors?Hide this!Advertise here!
how to measure and match source resistors 0,22-1ohm? elviukai Pass Labs 14 7th May 2006 05:15 PM
How to measure resistors below 1R bigpanda Parts 6 19th June 2005 05:02 PM
SMD resistors measure badly after soldering? motherone Parts 18 4th March 2005 04:57 AM
quick bias tolerance question...across source resistors Mattyo5 Solid State 6 12th October 2003 12:09 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
