Power Adapter for ACA Mono Blocks?
I tried digging through the forums and had no luck finding an answer. Do the Pass mono blocks use the same power adapter as the stereo units? I just finished building a pair and below is what I ordered.
MEAN WELL GST120A24-P1M 24V 5 Amp 120W Regulated Switching Table Top Power
Are there other cheaper alternatives to this that have worked well?
Thanks.
The one and only
Joined 2001
The Mean Wells are a little more expensive, but I have found them to be
quieter than most, and they do come with a warranty.
Two issues that you have to deal with on switchers -
The rating of the supply has to be at least the peak current draw of the
supply, not the average.
The switchers use sensing circuits to see if the the load has too low an
impedance, and some of them won't turn on into big capacitors. Others
will deliver limited current until the capacitor is charged.
And of course there is always noise....
On the other hand, if you want to do something totally over the top that's impractical from a cost, size, weight and usability perspective...
500VA 30+30 transformer > 25A Bridge rectifiers > 22mh toroidal chokes > 50V 30,000 uf capacitors > LT338 regulators (set at 23V) > 50V 30,000 uf capacitors. Connected to the ACA with Neutrik terminated star quad cable.
Kind of silly for a a measly 8 watt amplifier, but if you have all of parts in your amp-building stash, why not? Thanks to Nelson Pass for the excellent design.
Ken
