Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Pass Labs This forum is dedicated to Pass Labs discussion. |
Thread Tools |
#5831 |
"Probably fake, but not bad."
har har. The pot is mounted on the chassis which is to ground. The pot's ground leg of the potential divider ground to chassis. I think all 4 of the board's mounting holes are to ground. And it is mounted with standoffs that ground to the chassis. And then there is the ground next to the 24v which I have ground to the chassis. Are you saying to remove the ground next to the 24v in, or remove the board's grounding via the mounting holes? |
#5832 | |
Via the PCB standoffs. You have a lot of potential for ground loops which is probably what you are hearing. Are you using an SMPS power supply? You don't need to ground the chassis. The chassis only NEEDS to be grounded for safety if you are using a linear supply with a 3 prong power cord. An don't use the chassis as any sort of connection from the pot to the PCB or anything like that. You want the wires to be the path of least resistance...once we start introducing unequal paths to ground is where we start getting ground loops. It's OK for the chassis to be grounded, but it needs to not be the path of least resistance. Maybe a pic would help? Perhaps I am not understanding what you are doing correctly. |
#5833 |
I’ve only built tube gear and wondered about the potential for so many ground loops.
I’ll post a pic |
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
Korg NuTube is now available online | pmillett | Vendor's Bazaar | 156 | 24th December 2019 12:33 AM |
New tube tech from Korg | Newk_Yuler | Tubes / Valves | 38 | 15th January 2017 02:55 AM |
2 X PIONEER CDJ-1000 MK3 PLAYER, Korg M3 88-Key Workstation / Sampler,Yamaha Korg | holocoast | Vendor's Bazaar | 0 | 22nd August 2009 08:03 AM |
tapping into keyboard of Korg Polysix | mashaffer | Instruments and Amps | 0 | 5th October 2008 02:06 AM |
Just ordered a Korg EMX-1 | MikeHunt79 | Tubes / Valves | 5 | 19th May 2008 09:34 PM |
New To Site? | Need Help? |
