UGS-muse preamp GB
Thanks for the massive number of MP I received today to confirm your shipping infos 🙂
I will now create a separate spreadsheet with this.
So as explained, I spent a bit of time tonight to double check the accuracy Diyaudio vs. the spreadsheet and there are few deltas for which I'd like the persons involved to reconfirm.
Please double check the spreadsheet again which should now be correctly updated with the consolidation of both Diyaudio + spreadsheet (unless I made a mistake).
The names of the people from who I need a feedback are highlighted in yellow and the spreadsheet is in read only now to avoid issues with existing confirmations so please reconfirm on this thread if you want to participate in the group buy or not and I'll adjust the spreadsheet.
Then 2 specials cases, for jazz ok I confirm I can provide you some UGSv3 modules only if needed, I have some already in hand.
And for carsten.witt please confirm what you want exactly if you are still in because your request was not clear.
=> Spreadsheet link
Ah yes and should you see any mistake in my consolidating please let me know and I'll adjust.
One set for me also...
vannhoem - 1 set
Twitchie - 2 sets
Dennis Hui - 1 set
lancer - 1 set
Johnny Canuck - 1 set
astromo - 1 set
myl - 2 sets
trung224 - 1 set
briangasberg - 1 set
emyeuoi - 1 set
Hicoco - 1set
Analogdiy - 1 set
PsykoK - 1 set
fencki - 1 set
gionag - 1 set
HelmutHolz - 1 Set
schultzsch - 1 set
awh - 1 set
ItsAllInMyHead - 1 set
guyisme - 2 set
Fabian85 - 1 set
obh - 2 set
JoeyDD - 2 sets
Gyuri - 2 sets
Lapoulpe 2 sets
Kk74 - 1 set
MEnsing - 1 set
TEDAMP - 1 set
Stones - 1 set
Pars - 1 set
Boydk - 2 sets
Eriksson-1 set
Axelcs - 1 set
Meanie - 1 set
Flamethrower1- 1 set
mordikai- 2 sets
leejh - 1 set
secanbj - 1set
elwood625 - 1 set
hirscwi - 1 set
Naz - 1 set
miksi - 1 set
NihonJR06-1set
Drpro - 1 set
Total = 53 sets
PM sent to Alex and added name to spreadsheet.
For the sake of it, are there support for other displays other than the ones mentioned in the parts list ????
Panel from different vendors but with same controller IC, resolution and orientation may work. This is to be checked.
PT6314 and SSD1322 are the controller I implemented.
Not difficult to add additional ones but I don't have much time for this unfortunately 🙁
vannhoem - 1 set
Twitchie - 2 sets
Dennis Hui - 1 set
lancer - 1 set
astromo - 1 set
myl - 2 sets
trung224 - 1 set
emyeuoi - 1 set
Hicoco - 1set
Analogdiy - 1 set
PsykoK - 1 set
fencki - 1 set
gionag - 1 set
HelmutHolz - 1 Set
schultzsch - 1 set
awh - 1 set
guyisme - 2 set
Fabian85 - 1 set
obh - 2 set
JoeyDD - 2 sets
Gyuri - 2 sets
Lapoulpe 2 sets
Kk74 - 1 set
MEnsing - 1 set
TEDAMP - 1 set
Stones - 1 set
Pars - 1 set
Boydk - 2 sets
Eriksson-1 set
Axelcs - 1 set
Meanie - 1 set
mordikai- 2 sets
leejh - 1 set
secanbj - 1set
elwood625 - 1 set
hirscwi - 1 set
Naz - 1 set
miksi - 1 set
NihonJR06-1set
Drpro - 1 set
Total = 53 sets
Ok you are in.
vannhoem - 1 set
Twitchie - 2 sets
Dennis Hui - 1 set
lancer - 1 set
astromo - 1 set
myl - 2 sets
trung224 - 1 set
emyeuoi - 1 set
Hicoco - 1set
Analogdiy - 1 set
PsykoK - 1 set
fencki - 1 set
gionag - 1 set
HelmutHolz - 1 Set
schultzsch - 1 set
awh - 1 set
guyisme - 2 set
Fabian85 - 1 set
obh - 2 set
JoeyDD - 2 sets
Gyuri - 2 sets
Lapoulpe 2 sets
Kk74 - 1 set
MEnsing - 1 set
TEDAMP - 1 set
Stones - 1 set
Pars - 1 set
Boydk - 2 sets
Eriksson-1 set
Axelcs - 1 set
Meanie - 1 set
mordikai- 2 sets
leejh - 1 set
secanbj - 1set
elwood625 - 1 set
hirscwi - 1 set
Naz - 1 set
miksi - 1 set
NihonJR06-1set
Drpro - 1 set
Stanney2001 - 1 set
Yes please.
One thing I realized, the PCB set in the GB at the moment is identical to the one I proposed on the French HCFR forum in the past and does not include the pre-regulation for the 2 preamp boards. The original reason behind is that this was an upgrade for the UGS AI design that was already including some pre-regulation stages named "simple UGS power module".
If you check the photos those are the modules I use in my preamp and they work well.
I can add them to the list of PCB to manufacture (for a total of 16 then in the kit), I just need to find the gerbers on HCFR.
As an alternative and thanks to my friend Eric.D, I am now in position to propose for this pre-regulations a PCB set based on a positive / negative Salas shunt modified by Eric to fit the UGS power needs. I never used it in my UGS muse preamp for lack of time, however the Salas shunt are very good power supplies and I tried them on the DAC I am designing currently that uses a very similar gain stage to the one used in the UGS muse and powered by Eric's modified Salas shunt and they are working really well.
So this is to propose a choice here, either with the pre regulation included in the original UGS AI or with a pair of positive / negative Salas shunt.
The only issue with the Salas shunt is that they need more current so bigger transformers that won't fit on the PCB included with the transformers / rectifiers in the GB.
But for those that will use a completely different transformer design (like Ine for example) then Salas shunt is a very good option ... 🙂
This long message to ask for your preference here, I will reopen the excel for you to add your need, I can propose both options too if some wants to try...
PS: Eric feel free to complement my comments if needed.
