About possible Babelfish J interest
Old 22nd March 2020, 11:05 PM   #651
mbrennwa is offline mbrennwa  Switzerland
mbrennwa's Avatar
Originally Posted by Zen Mod View Post
it would be , in case that I know that you have entire chain fully differential, properly balanced and floating
which nowadays is rarely the case, most output stages being electronically balanced, and often not having equal Rout of phases
though , you can try , and leave option which most suits you , sound-wise and hum-free wise
The source has a transformer output, so it is properly balanced and floating. I just wanted to be sure that I am not missing anything. Changing from one setup to the other will not be difficult, so I'll just give it a try and see.
Scan waveguides (elliptical / circular) MATAA audio analyser Open Source Monkey Coffin
Old 5th April 2020, 06:03 PM   #652
mbrennwa's Avatar
Default Oscillation!
So I just finished building the first channel of the amp as shown in post 644. As far as I can tell, the thing almost works. However, the lower MosFET starts oscillating if I turn up the bias voltage.
What I tried so far:
  • Removed the global feedback loop (for easier debugging)
  • Tried a larger gate stopper (did not help)
  • Controlled the gate from a regulated DC power supply instead of the input/driver circuit (oscillation is the same).
Any ideas what else I could try?
Old 5th April 2020, 07:13 PM   #653
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
try usual 1nF capacitor cure , 2 positions per channel
see attached file
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 10th April 2020, 11:27 AM   #654
mbrennwa's Avatar
Ok, I tried that. Didn't help. I believe it was even a little bit worse.
The only thing that kills the oscillation was to use a different MosFET in the Aleph source. I found an IRFP150 floating around the bench, and tried that (leaving the 2SK214 in the lower position). Oscillations gone!
Are the 2SK214 particularly sensitive to oscillation?
I have to say that I don't understand a thing about those oscillation issues. How do they happen?
Old 10th April 2020, 11:45 AM   #655
Zen Mod's Avatar
well, I didn't catch that detail , that you're using some other mosfet in Aleph CCS
2SK214 there ........
now it seems that I didn't catch anything ...... are you making some mini iteration , with T0220 mosfets?
however..... main problem you had is lower Ugs of mosfet used in Aleph CCS(comparing to IRFP), so small bjt is having lesser voltage window, causing oscillations
no special difference if you use ( even if yuo can without problems) Audio-approved part there, most things are dominated with small bjt and even its job isn't critical
but everything needs to be optimized , as is already in original Papa's concept
Old 10th April 2020, 11:57 AM   #656
mbrennwa's Avatar
See my pre-previous post: I built the amp as in post 644 (here).
Of course I could save the precious 2SK214 and use something cheaper in the Aleph source (and I probably will). But I'd like to understand what's going on with those oscillations. What's the story with that voltage window thing?
Old 10th April 2020, 12:03 PM   #657
Zen Mod's Avatar
IRFP needs approx. 4V for gate being above source , and you have put small bjt in that voltage window
you used 2SK there , which is having half of IRFP voltage ( max 2V ) from gate to source , and you still putting small bjt in that window .... so it's sorta voltage starved
same as when you put sack of cement on your shoulder and need to bring it 100 feet
not so hard, even if boring, if you are walking with your back straight
try the same, while walking through 1.3m high corridor.... after some time you'll have your back snapped, or - in best case - you're going to fight for your breath
same with small bjt ....... he's fighting for its breath, while behaving hysteric (with reason)
transistor demands some minimal rail voltage for at least so-so linear operation
Old 10th April 2020, 01:15 PM   #658
mbrennwa's Avatar
Ok, I am tall, so I need a bigger tunnel. Makes sense. Which MOSFET would work well? IRF610? IRF530? A TO220 part would be nice so I can re-use my contraption to fix the outputs on the heatsink.
Old 10th April 2020, 01:35 PM   #659
Zen Mod's Avatar
any of IRF small ones you have in drawer, use one with greatest xconductance
Old 11th April 2020, 03:13 PM   #660
mbrennwa's Avatar
I couldn't find a TO220 IRF, so I ordered a few. Left the IRFP150 in there for the moment.
In the meantime I had some fun with the function generator and the scope. I found that the square-wave response was slightly deformed on the falling edge. I don't know what this is, but I could make it go away by inserting a 15 pF capacitor from gate to drain of the gain MosFET (directly on the pins), as shown in the attachment. Any ideas what's going on with this?
(sorry, I forgot to take some screenshots from the scope)
About possible Babelfish J interestHide this!Advertise here!
Babelfish J2 , just one package for sale Zen Mod Swap Meet 6 22nd April 2015 01:59 PM
For interest M Gregg The Lounge 0 26th September 2014 08:50 PM
Just for interest.. M Gregg The Lounge 0 17th July 2013 07:56 PM
Babelfish J combos Zen Mod Swap Meet 0 18th June 2007 11:18 AM
Maybe of interest... Ropie Analogue Source 2 20th April 2004 06:18 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
