Using 30mm diameter caps, you could mount eight (8) of these on the DIYaudio PCB -
33,000uf 25v
ECO-S1EP333DA Panasonic Electronic Components | Mouser
33,000uf 25v
That's great!
Just use the DIY store PCB with 25 or 30mm caps, you can mount 8 of them.
Look at this - here is a 25mm dia, 22,000uf 25V Panasonic ECO-S1EP223CA Panasonic Electronic Components | Mouser
or this one. 35V 30mm.
ECO-S1VP223DA Panasonic Electronic Components | Mouser
Here is a link to the caps I plan to use > http://www.diyaudio.com/forums/vend...vishay-058-15000uf-40v-caps-f5-turbo-amp.html I hope 8 x 15000uf isn't to wimpy ! They are 35mm diameter & 50mm tall. Also I'm gonna use a Antek # AS-4218 transformer.... Sorry can't wait for the new Diy PSU board to come out.
WithTarragon -
You are wrong. This is what the thread is. It has not degenerated, it is still quite useful.
The guide itself will always be on the top post, where it can be found easily. People building F4 are very welcome to post whatever questions/observations/comments in the thread.
I agree with 6L6, Had it not been for his wonderful guide I would not have started building. I have spent almost 3yrs acquiring the best parts I could find at a reasonable price. Money was not the only problem I had, also mostly it was fear of making a mistake in my build ! 6L6 has mapped it out with super pics which for me is really great. Most of what I read is very hard to understand so I tend to ask a lot of what seems like foolish question's to others. To make a long story short I'm very great-full ! Forever learning Thank-you Thor61
In the power supply section goatee has done a spread sheet for sizing power supply caps. The first cap before a choke or resistors should be limited say 40,000 uf or less this keeps the bank from stressing the diode bridges with huge turn on current . Look at what Goatee has don it fine work for an in depth view. My take on this amp is about 120,000 uf total per voltage leg ( = or -) . However if you use a choke before the largest part of the bank then maybe 200,000 uf . Cost of that much power supply is up to you as for the knee on the curve of ROI bends . RegardsWhat is the design criteria for sizing caps in PSU and at what point is bigger a waste of money?
- A guide to building the Pass F4 amplifier
