L'Amp: A simple SIT Amp
Old 17th October 2019, 03:30 PM   #3101
Rodeodave is offline Rodeodave  Austria
hates ground loops
Rodeodave's Avatar
The two wire links that join the rails were what I had on hand yesterday evening. I intend to use a copper bar or plate to replace them.
I'll also be using shielded RG316U cables for the input wiring.
I haven't done too many measurements yet, just a quick tuning of the sweetspot (~52VDC supply after reg, 2.3 A Id, 0.13% THD). So far so good.
I'll be pulling some numbers from the circuit over the weekend.
I've been listening to the amp though the HD800 for an hour this morning. In one word, euphonic.
Gravity - Making the G since 13.7 billion B.C.
Old 18th October 2019, 10:49 AM   #3102
maxlorenz is offline maxlorenz  Chile
maxlorenz's Avatar
Originally Posted by Zen Mod View Post
in this case he's safe , simply because each (of these two) cap is on single rail , each is having own separate ground feed and there is no current flow between them
in short - Lucky Bztrd
OK. I confess I didn't dare to check thoroughly the drawing
At the risk of being repetitive, I recommend to add later a good input section. That helps a lot with complex music, like big symphonic works.
As time allows, I promised myself to cascode (or bootstrap) the output, like I did with the ZCA AKA Zero Component Amp.
Best wishes,
M.
Old 18th October 2019, 11:02 AM   #3103
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
put link of your ootoobe channel on your blog
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 30th October 2019, 08:11 PM   #3104
hates ground loops
Rodeodave's Avatar
Good news, everyone!
I found the aluminum plate from the cutout for the switched IEC power inlet and am now using it to connect all the circuit grounds. And it works, beautifully! Not the slightest hum with a source and headphones connected.
I took some measurements with an input of 1V at 1kHz. Output (over 10R load) was 2.466V or 7.83dBV. Distortion was 0.16% (drops down to like 0.04% at headphone listening levels) and S/N ratio was just shy of 91dB. Not too bad I'd say.
Attached you'll also find a snapshot of the residual distortion signal (purple trace) and a simple FFT. H3 ia slightly dominant over H2, and H4 is already way down. I'll be playing with the sweet spot and the resulting spectrum over the coming weekend, should be fun.
Old 30th October 2019, 08:32 PM   #3105
Zen Mod's Avatar
yup , sweetspotting , to invoke 2nd above 3rd , as is logical for part used
Old 9th April 2020, 03:47 PM   #3106
juanitox is offline juanitox  France
juanitox's Avatar
Default Oops i did it again
having time to spend as many here , i have rebuilt for the X times my Sitamp
exit hte big Tokin THF51s with CCS and Nemesis TANGO transformer version
and return to the simple Sony Vfet with 12,7 R load . 61V B+ ( 43V 1.45A for the VFET)
fixed bias with Cinemag input transformer. works perfectly as usual
but i wonder for those who have distorsion meters what will be the sweet spot
with my " higher" voltage than usual for resistor load Sony 2SK82 ?
French is not a crime.
Old 6th May 2020, 11:31 PM   #3107
Ylab is offline Ylab  Canada
Hi there,
I’m planning a built of the L’amp with the 2sk182es + hammond 193v. I’ve seen a video of mr Rothacher talking about the development of Soundhappy’s L’amp with the 2sk182es but have not found any info fallowing that. Is there anybody that have built the L’amp with the 2sk182es that could give me some info about the psu voltage for that configuration?
Merci !
Hubert
Old 7th May 2020, 12:20 AM   #3108
Soundhappy is offline Soundhappy  France
Soundhappy's Avatar
It's was simplified version schematic with 2SK79 and 2SJ28 vfet's by Mr. MR
What To Do With Those 2SJ28's
link 2: What To Do With Those 2SJ28's
2SK182ES L'Amp version find in this video Lab Hangout #4 start at ~16min10s.
Oh yeah I am Mr. MR fan boy and ask more about less top secret stuff Joke
class A amplifiers with full range speakers
sings like angels in heaven
Old 7th May 2020, 01:39 AM   #3109
Soundhappy's Avatar
Originally Posted by Ylab View Post
Hi there,
I’m planning a built of the L’amp with the 2sk182es + hammond 193v..
I am not aware , probably no one has build L'Amp 2SK182ES with inductor load
Meantime this is instructive article :
http://blog.audiomaker.tech/pdf/lamp%20part%20deux.pdf
another about gate leakage and bias:
Fun With PASS-SIT-1 | AudioMaker
Old 7th May 2020, 01:50 AM   #3110
Yes that’s the video I was talking about, at 14min he talks about Soundhappy 2sk182 amp
Thank you Soundhappy for your answers and all the links it’s really appreciated!
Hubert
L'Amp: A simple SIT AmpHide this!Advertise here!
Srajan has the 1st SIT amp for Une dégustation vizion Pass Labs 133 19th October 2019 08:31 AM
L’Amp: A Simple SIT Amp: Part 1 Michael Rothacher diyAudio.com Articles 23 1st September 2014 01:02 AM
SIT Amp Article Out Now Variac Site Announcements 0 2nd December 2011 07:55 AM
SIT-Preamp VladimirK Solid State 36 27th August 2011 08:36 PM
New SIT - old problem StevenOH Parts 2 13th June 2008 10:46 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
