Relay magic trick required
Hey everyone,
I need to fix a pioneer SX 980. The 48V MSJU relay Needs replacing. I have a suitable Omron, but the contact pins are a bit too close together. Dies anyone have a trick to deal with this or do I need to get a base ?
Thanks, Pete
Sorry if this advice is stupid but if I understand your question correct, do you have two possibilitys.
1) Make a pcb to the relay and fitting pins on the bottom side.
2) bend a stiff wire that can go from one relay leg to the pcb hole and then make a way to fasten the relay, maybe with hot glue. You shall end up with a squarish bottom block where the bend wire goes from the fasten relay down trough the glue block and fits in the pcb hole..
