Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Umbilicals
Umbilicals
Old 18th September 2019, 05:59 PM   #1
WntrMute2 is offline WntrMute2  United States
WntrMute2's Avatar
Default Umbilicals
I am building a phono-stage with separate power supply. I was planning on twisting 3 14 gauge wires together for the 6.3V heaters x 4 and the same for the B+ voltage. I was going to pass that thru a few feet of insulation from some Canare 4s11 star-quad cable I'd remove the conductors from. It occurred to me that maybe the 4S11 in it's star-quad form might suit the bill just as it is for the B+ of 250V and the heaters. Thoughts?
Old 18th September 2019, 07:59 PM   #2
willsw is offline willsw  United States
The Canare 46X series of cables is considered a great choice for DC umbilicals when used as a star-quad.
I'm not sure of your exact needs. How many conductors do you need in your umbilical, and what are the voltage and current requirements of for each conductor?
The 4S11 wired as star-quad would give you two 11 AWG wires, which is rated for 12 amps. It seems unlikely that your phono stage would need 12 amps of current. 4S6 has 20 AWG conductors, which gives you a pair of 17 AWG conductors and a rating of about 3 amps.
Old 19th September 2019, 05:07 PM   #3
Speedskater is offline Speedskater  United States
Speedskater's Avatar
Is Canare 4S11 rated for 250V DC ?
Kevin
Old 19th September 2019, 07:52 PM   #4
WntrMute2's Avatar
I'm not 100% sure hence my question to this forum.
Here is the data sheet.
http://www.canare.com/UploadedDocume...er%20Cable.pdf
Old 19th September 2019, 07:56 PM   #5
PRR is offline PRR  United States
PRR's Avatar
Not rated for any voltage at all. {EDIT: it is *}
However it is 27mil of PVC. If it was 90mil it could be rated and tested for 5,000V.
https://www.anixter.com/en_us/resour...on-levels.html
So the 27mil "should be good" for 1,500V.
Of course gaps skips or nicks in the PVC could greatly reduce this breakdown.
OTOH there will be two 27mil between conductors, making 3,000V. And reduced chance two defects will lay together.
{*} Small fine print: "Dielectric Strength = 500V AC / 1min."
If I believed it would breakdown at 501V for 61 seconds, I would fret about 250V. But I am pretty sure they know it is good for thousands of Volts, the market is not shopping for hi-Volt, and they do an occasional sample-check at a convenient 500V 1min (there's a standard test box for this).
Old 19th September 2019, 08:38 PM   #6
WntrMute2's Avatar
Thanks for the input gentlemen.
UmbilicalsHide this!Advertise here!
Anyone know some good high current plugs and sockets that can be used for umbilicals? hifinerd Parts 14 8th September 2010 03:47 PM
Sourcing sockets and plugs for power supply umbilicals jmillerdoc Tubes / Valves 27 21st February 2010 02:08 AM
Copyright ©1999-2019 diyAudio
