JBL 2206H enclosure size?
There are a couple of effects you should be aware of, even if they won't be deal breakers.
First, reducing the amount of bass coming from this passband may change the required crossover alignment to your subs - not a problem if this is for developing a new rig, as you'd be doing that from scratch anyway, but something to bear in mind if this is intended to be a drop in replacement in an existing setup.
Secondly, moving to a smaller sealed box means there is less opportunity for the driver to get rid of excess heat. That means you may get power compression setting in a little earlier than in the old box.
HTH,
David.
I have finished my new cabinets, I went with 30lt total volume tuned to 75hz, this gives me a measured flat response down to 100hz, they are very compact now and I'm super happy with how they turned out.
