ARTA
ARTA
Old 26th April 2019, 07:28 AM   #801
rich08 is offline rich08  Slovakia
Originally Posted by Denri View Post
I'm sorry for noob question but I still not able to understand clearly how to set proeprly Gating window in ARTA in measured impulse reponse.
I try to measure 10" speaker with install height 950mm and on same height mic with a distance between them 1m. Vituixcad says that splitting frequency to connect with nearfiled measurement is about 3xx Hz and windows time until first reflection is ~3.3ms
But on every video\articles I see only one impulse while I see two of them. How so set start\stop gating window properly?
I use dual channel mode measurements. Pic of measurements is below
Everything is right. The second impulse is important to you.
Old 26th April 2019, 08:41 PM   #802
Denri is offline Denri  Russian Federation
O, nice to know that so
now just curious about first impulse nature
Old 27th April 2019, 07:36 PM   #803
It is reference position for dual channel measurements. It
is the position of zero delay. In ARTA, the reference position is sample index 300.
Old 29th April 2019, 02:45 PM   #804
mbrennwa is offline mbrennwa  Switzerland
mbrennwa's Avatar
I may be wrong, but if the the first impulse (red) is the reference from the loopback connection, it looks a bit too noisy for my liking. The loopback reference should normally be a very clean impulse without the hash seen here. What do you guys think?
Group buy for augerpro waveguides for Scan Speak tweeters here
Old 29th April 2019, 03:16 PM   #805
Davey is offline Davey  United States
Ivo,
The Right/L or Left/R input selection in FR2 is a terrific addition to ARTA.
Using this and the capability of Preferred input channel and Propagation delay, allows to remove latency of DUT in any configuration.
Thank you.
Dave.
Old 29th April 2019, 07:18 PM   #806
iMat is offline iMat  Croatia
You are not wrong.
When there is small replica of distorted antialiasng filter response, it is in 99% cases result of high cross-talk between left and right input channels. Some converters are really bad in this sense, i.e. Behringer UC202, or motherboard systems.
In ARTA user manual (chapter 4.2) I have described how to test soundcard dynamic range and cross-talk.
If your soundcard has large cross-talk you should use single channel measurements, but the problem remains when you measure impedance.
Ivo
P.S. You may get some IR replicas when measuring with clipped swept sine.
Old 14th May 2019, 07:23 PM   #807
Thanks for comments and it sounds dissapointing for me about quality of sound card.
Well I use E-MU 0202Usb and windows 7.
For measurements I use E-mu phones one channel output -> Emotiva A-300 power amplifier with two resistors voltage divider on soundcard right channel input and speaker measured -> Behringer ecm8000 mic to get
Well like here http://www.artalabs.hr/AppNotes/AP1_...-2-Rev1Eng.pdf on page3 but simplified without switches.
I will try to measure card loopback like in chapter "4.2. Testing the soundcard" wthout amplifier and with amplifier then.
p.s. I used a-300 because i dont have another one and i tried car amplifier previously Revolt Audio SS 85.4 with 60Ah battery used for LIMP impedance measurements and RLC measurements of Resistors and capacitors and found that with A-300 measurments more close to specification of components so it is more accurate I suppose
Old 14th May 2019, 07:35 PM   #808
meh.. as messages premoderated just thoght that no need to check card in loopback mode with amplifier connected as for measurements only one channel of amplifier is used.
Old 22nd May 2019, 08:49 PM   #809
tmuikku is online now tmuikku  Finland
Send a message via ICQ to tmuikku
Hello,
I did impulse response measurement using External Excitation. Any idea why Burst decay and some other tools won't work? Says "To use this analysis, record or import impulse response file!"
Thanks!
Old 22nd May 2019, 09:06 PM   #810
Zung is offline Zung  Switzerland
...[/I]
How do you do this?
I've tried their beta driver with Windows 7, 8, 10 over the years, NO success. Last time with Windows 10, it frozen the PC solid.
Just curious, the E-MU went to a closet, and I've been living happily with a Focusrite Scarlett.
ARTAHide this!Advertise here!
Arta box. miklos Equipment & Tools 2 19th September 2014 07:27 PM
Help with Arta- HOLMImpulse viki_v2 Software Tools 2 12th September 2012 02:04 AM
arta vs cliowin ermes Multi-Way 0 4th March 2011 02:37 PM
ARTA - using ARTA to measure room acoustics! OMF Software Tools 0 25th November 2009 01:55 PM
ARTA help Cousin Billy Multi-Way 2 13th February 2009 12:16 AM
Copyright ©1999-2019 diyAudio
