Best Midwoofer in Dipol-Configuration
we have many some threads about the best selection of a dipol-tweeter with measurements of the polar pattern incl. backside. (for example in this thread: On the directivity of dipole tweeters)
But whats about the MF? The backside radiation pattern of the mids that i have seen do make some hickups and dont make a perfect dipol8 over the complete midrange.
So the goal of this thread is to make a list over some drivers for the midrange (200Hz-4khz). What is the usable frequency range for a good 8-dipol pattern for every driver (Backside and Frontside)?
Probably we can get some nice driver combinations....
Best regards, Tomas
UPDATE 26.01.21:
Driver List in dipol configuration:
2" Visaton FRS5X usable 1,5-4,5 khz
(Frontside Backside Pattern: https://www.diyaudio.com/forums/att...ectivity-dipole-tweeters-frs5x-front-rear-gif)
3" TC9FD18 usable 1,5-2,5khz
(Frontside pattern: https://www.diyaudio.com/forums/atta...olars-0-90-png
Backside pattern:
https://www.diyaudio.com/forums/atta...ars-90-180-png)
4" Audax HM100Z0 usable till 1,5khz
(Frontside Bacside Pattern:
https://www.diyaudio.com/forums/att...9848301-3-ob-hm100z-0-90-180-4ms-124-vert-jpg)
4"Peerless HDS PPB 4-25/08 (HDS-P830870) usable till 1,7 khz
(Frontside Backside pattern:
http://www.diy-hifi-forum.eu/forum/attachment.php?attachmentid=3199&stc=1&d=1298815177)
Driver List in dipol configuration without measurements:
Scanspeak 15M/4624G00 used 250-2,5khz from kaameelis
(Akabak simulation MTM: https://www.diyaudio.com/forums/att...woofer-dipol-configuration-15m4624g00_mtm-png)
SB17CAC used till 1,5 or 2khz from CharlieLaub
(In Thread: In Pursuit of the 20-20k dipole)
I has no direct 15M/4624G00 polar plot measurements, but I has Akabak simulation on triangular MTM baffle at tweeter axis/level.
Is seemt, that we cam use the modst drivers till their cone breakup:
2" till 4khz
3" till 3khz
4" till 2khz
and so on...
But some of them have hickups in the LF. For example the frs5x at 1,5khz. Is it audible?
I took a look on some drivers till 3,5" and their distortion. The following drivers could ve very nice. Do somebody has the frontside or backside radiation pattern of them?
MCM 55-5650 !!!
Fr88EX
Faital Pro 3FE22/25
Dayton RS 75
Hivi B3N
