LXmini Clone
LXmini Clone
Old 1st June 2020, 05:52 PM   #1
Jokerbre is offline Jokerbre
Default LXmini Clone
As proof of the concept, I decided to make a clone of the LXmini speaker.
The results are excellent both audible and measurable.
The drivers I used are Mivoc swm 68 and TC9FD18-08 which in my opinion is a far better driver than Seas FU10RB (H1600-04).
I ordered the Seas L16RN-SL (H1480) waiting to arrive to make the final version.
If someone is an expert in designing parts for a 3D printer, they might be able to contribute to the design by designing the upper part that comes on the tube.
Off axis measurements are 0-22-45.
The microphone I use is Umik-1. It has a horrible feature to bring down the response over 18khz so I don't know the real situation above.
Crossover is terrible minidsp 2x4.
Old 1st June 2020, 06:17 PM   #2
Ugg10 is offline Ugg10  United Kingdom
Similar 3D parts are already on thingiverse.
Hifi Speakers Based on the Linkwitz Labs LX Mini by Bathys - Thingiverse
Old 1st June 2020, 06:29 PM   #3
Similar but not for Seas L16RN-SL (H1480).
I have found on web this picture...
Old 1st June 2020, 06:38 PM   #4
The main problem is DSP.
The MiniDsp 2x4 is very bad.
Avoiding ADC conversion would be better as well as internal DAC.
I also tried the MiniDsp curryman DAC oh my god what a disaster.
It's like someone has a pillow in front of the speakers.
Old 1st June 2020, 09:48 PM   #5
If you only have digital sources, this is my solution.
DSP Crossover project
Old 10th June 2020, 10:11 AM   #6
Metguy2000 is offline Metguy2000  Denmark
For my LXMini I purchased a Beocreate unit Beocreate | HiFiBerry with a Raspberry Pi but the power for the FR unit was too little. I am now working with the Zoudio unit zoudio actually 2 pieces in TWS as I plan a LXMini+. Running at soundlevels of 80dB I am getting THD around 0.2-0.3% above 200 Hz from the speaker that is. I plan a post in the Zoudio thread ZOUDIO AIO4CH: 4-channel amplifier with DSP and Bluetooth later.
  Reply to this post
LXmini CloneHide this!Advertise here!
LXmini's garym999 Multi-Way 5 12th May 2017 10:21 PM
CLD: LXmini rich31td Construction Tips 22 20th December 2016 06:00 PM
Sub for lxmini drewan Multi-Way 6 7th December 2015 05:12 PM
lxmini clone with MA CHP70? wendelltate Multi-Way 0 4th February 2015 04:26 PM
DIY Modified LXMini clone sfhobbles Multi-Way 8 6th August 2014 10:55 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
