The Kjeldsen OB build thread
Both black. I will see how much it will cost covered with PU leather. For this I will have to find a craftsman
Ripole / W baffle
Hi
The reason why you you do not use the ripole is that because you need to be able to go higher in frequency?
I have 2 12" woofers and want to go with the W shape for bas.
My midrange will probably be the 9½" SB satori woofer, that can go deep enough for a W baffle bas, I hope.
Tweeter is the big ESS AMT1.
best regards
Uwe
Little issue occurred. I like to mount units from back, but for the fullrange too little wood is left for proper fixture. One screw went through and one hit a knot. It made some cosmetic damage. I had to mount differently.
