Open baffle form factor questions
Old 12th January 2020, 02:38 PM   #11
aagas is offline aagas
@LineSource -- Gotta love that you keep trying (and with a custom graphic too!) ;-)
Old 12th January 2020, 04:10 PM   #12
@silent_mike
"...The first panel is obviously similar to multiple stacked BB plywood..."
The Spatial Audio website states this. Good observation.
My wife, an architect, may have access to sheets of this material.
"...the big question to me is how the two panels connect together."
Seems like a number of possible ways to do this, but it gets tricky because one would still need to have the ability to disassemble the speakers to change or tinker with drivers and cables.
"My guess is the front baffle has to have a firm secure mechanical connection to the metal feet/stand. That suggests the 2nd panel could be decoupled?..."
Interesting. I'd love to get an up close look of how Spatial does this.
"The simplest effective rigid damped composite panel a DIYer can make is to bond two layers of relatively thin (say 9mm?) BB ply with Green Glue -- the acoustic damping goop which also doubles as glue."
That can work. Thanks.
I do have another option for non-resonant material. My wife's architecture firm (with some wait time) can often get Corian from her construction sites where a contractor has miss-cut a counter top. We've cut down some of these pieces and used them for smaller counter tops in our home.
With a little luck, I could get enough Corian for two baffles for each speaker.
This would still run into the issue of decoupling, but might work pretty well. Thoughts?
"The old right-angle ledge on the back bottom of the speaker like on so many electrostatics etc seems a fine place for such things. "
Certainly the most logical and obvious. In such a configuration, it seems like I'd still benefit from some kind of decoupling of the amps and DSPs. Any thoughts?
I had just started to look at the
"...Hypex FusionAmp FA123..."
plate amp you recommended. It seems like a great fit for the project. Thanks.
Although I may have missed something, Hypex does not appear to have a DSP available to DIYs anymore. Any suggestions? miniDSP has a number of options. Guidance appreciated.
A few additional questions for any takers.
The attached image shows my thoughts on two possible configurations for my system. Note, I use only computer source audio. The computer I use currently connects via an optical cable to a DAC that has a volume control. The DAC then to my current speakers.
In the attached image, Configuration 1 imagines using a 3-channel DSP for each speaker. Configuration 2 imagines using a 6-channel DSP that supports both speakers.
Configuration 1 (if it can work) would leave me with an audio system (at least visually, keeping my partner in consideration...) with only two speakers connected to a computer -- minimalist appearance (with hidden complexity).
Would Configuration 1 work? If it does, how do I connect the computer to the two DSPs? Two USB cables? Can I split the optical output from the computer?
Its the details that get you.
Thoughts appreciated.
File Type: png Screen Shot 2020-01-12 at 10.41.35 AM.png (127.2 KB, 179 views)
Old 12th January 2020, 05:46 PM   #13
Juhazi is offline Juhazi  Finland
Juhazi's Avatar
Hypex FA123 boards have built-in 3 channel dsp and amps. GUI is a bit tricky.
Hypex Electronics B.V.
The New Hypex Fusion Plate amps
Radikal aktivist AINOgradient speaker project
Old 12th January 2020, 06:03 PM   #14
@Juhazi --
That simplifies things. The build becomes very straightforward indeed! A little GUI trickiness seems like a small price to pay.
Many thanks for clarifying this.
So how do I deliver my computer source to each plate amplifier?
The link to The New Hypex Fusion Plate amps discussion has 198 pages (seems like these plate amps merit the attention). Any direction to a specific discussion of connecting my computer appreciated.
I recognize I may have simply overlooked something obvious.
Old 12th January 2020, 06:08 PM   #15
silent mike is offline silent mike  Canada
Corian would not be my first choice; there've been posts elsewhere on this forum that it is more resonant than you would think. Not having worked with it first hand, I don't know for sure. It might be worth a try -- just about anything braced well enough becomes rigid.
BTW, I was only conjecturing that the second panel is decoupled. Maybe it's firmly connected in order for its internal damping to act as the "vibration sink". You might have to get an up close & personal look at the Spatial Audio spkr. Maybe there's a video on youtube that shows fine details?
Actually, I think the better option is to create a really well damped but still rigid main baffle. This has the benefit of stopping the vibrations right where they start at the drivers rather then let them propagate into the panel, which then have to be suppressed. I've been thinking about a 2 ply 9mm or 12mm BB with Green Glue between them, and the drivers mounted only on the outside layer of plywood, not allowing the driver mounting bolts to squeeze the 2 boards any tighter, to avoid mechanical short circuit. The idea is that the GG damping layer absorbs the vibrations, and the back plywood layer adds stiffness without picking up the vibrations from the front board.
If I was doing it, I'd use some kind of solid frame -- hardwood, BB, metal tubing (internally damped with expanding foam) whatever -- as a floor base for the speaker frame, but extended long enough behind the speaker to house the amps etc. That housing could be decoupled from the base with silicone rubber, sorbothane or other elasto-visco damping sleeves, plugs, etc. Similar to what's used for compliant turntable suspensions, if need be, though I doubt the housing needs to float like a Linn LP12. Your wife probably knows architectural materials that can be used.
You know the FA123 has DSP built in?! External DSP is not necessary. You only need to multiply the optical output at your PC to run one to each speaker. And if you use phono plug/wire SPDIF, the FA123s have pass-through output which means you can run one cable from PC to one speaker, then daisy chain from that spkr to the other.
Old 12th January 2020, 06:29 PM   #16
@silent_mike
Brilliant. Every mystery revealed!
I'll start with the pair of FA123s to replace my beloved A40s. (hmmm....? I may yet get some more life out of them with my mini home theater alcove).
I can discretely fasten the FA123s to the speaker stand with dampening in mind.
I already have very rigid and I think a pretty non-resonant vertical frame supporting my current baffles - 2" aluminum tubing with 1/4" walls into which I hammered wooden 2 x 2s. I thought to spay in dense urethane foam, but it the wood inside the aluminum has served me pretty well so far (although I expect forum members may have multiple suggestions on this).
With the new amplification & DSP up and running, I'll explore replacing my existing front baffles or even those aluminum verticals.
I'll post pics as things progress.
Many many thanks to you and all other participant.
Old 12th January 2020, 06:31 PM   #17
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
All that matters from a sonic point of view is that the baffle doesn't resonate, vibrations per se don't matter if they are small and spread across the spectrum.
Old 12th January 2020, 07:04 PM   #18
Juhazi's Avatar
FA board can be fed with digital or analog input.
If source is digital, one plate is "master" that gets the signal, and is configured as L or R. Then just connecct a digital cable from it to the other and configure it as slave. So - this applies only to stereo signal splitting. Multichannel gets more tricky...
I use analog RCA feed from my HT amp, each FA unit is "master"
Like Scott, I can't see big/worthwhile advantage of a sandwich open baffle. There are so many more much much more difficult issues to solve!
Baflle size is a very important factor to make a full range dipole working. It is easy to make the midrange sub-baffle narrower.
Dipolplus - Alles über offene Schallwände
Tech
Electro-acoustic models
Old 13th January 2020, 03:50 AM   #19
LineSource is offline LineSource  United States
LineSource's Avatar
Baseball allows 3-strikes. Here is my third controlled directiviy pitch....
Are your investments directed to Music Magic, or Architectural Style ?
We have 350-lb Apogee Full Range LineSource dipole speakers in our living room
---all analog with Krell crossovers and amps.
-We added several Fichus trees behind them for diffusion, BIG improvement.
-We added poly-fill screens to walls 10-feet behind our listening sofa to absorb reflections. BIG improvement.
For Music Magic, dipoles require extensive room treatment.
For Music Magic modern controlled directivity horn speakers create an excellent soundstage in ordinary rooms with modest room treatment. (my first strike BMF_1 design). --HORN KEY: keep the listener several feet away from the (rear)walls.
Some listeners like the accurate imaging that high directivity speakers give. (you are there)
Some listeners like a controlled BUT diffuse soundfield that surrounds them. (they are here)
========3-strikes AMEN==============
Poured concrete has been used for dipole baffles.
You could put a sealed 0.5 cuft Mid-Tweet wood cabinet on top of two 15" dipole woofers. The tweeter would be on the cabinet bottom to match 36"-39" seated ear level. Because of the low ~120Hz crossover frequency to the dipole woofers, a top midrange will integrate well with bottom woofers.
Old 14th January 2020, 01:29 AM   #20
This morning I ordered a pair of FA123s from Madisound.
They advised me I could download the configuration software.
Afterwords, I found some confusing information about the software required to configure the FA123s.
See: Hypex Filter Design
It looks like this software only works with Windows and costs 1,000 Euro!
This seems far out of line.
But...the Fusion Amp User Guide says:
Hypex Filter Design (HFD)
HFD is a free software tool needed to configure the FusionAmp. To protect your valuable drivers, the DSP does not contain a filter out of the box. A filter needs to be configured and uploaded before the FusionAmp will produce an output signal.
Maybe the amps come with basic software and you can buy more advanced?
Have I looked at the right thing?
Do the amps come with configuration software to set up the DSPs?
Does software exist for DIYers?
How does one actually do this?
1,000 Euro + getting or borrowing a Windows computer just feels wrong.
Open baffle form factor questionsHide this!Advertise here!
WTB: GrubDAC or similar form factor USB DAC populated PCB HiGHFLYiN9s Swap Meet 2 3rd November 2014 11:12 AM
HIFI sound in zvox form factor? Lefty78 Multi-Way 3 29th March 2013 03:27 PM
Open baffle servo vs. high damping factor fudce Multi-Way 0 22nd March 2013 02:54 AM
Visaton Quadro questions. Box to Open baffle and other questions. Bas Horneman Full Range 2 1st March 2013 11:53 AM
zaph's BAMTM form factor gonar Multi-Way 0 2nd January 2007 08:01 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
