Filter recommendation (using Hypex Software Design)
Old 7th January 2020, 09:22 PM   #151
Geertidow is offline Geertidow
Well I will leave that up to Dirac
Old 8th January 2020, 08:02 PM   #152
I did some equalizing in the lower end (before dirac): 20200107basscorrectioneq - ImgShare.io
Old 8th January 2020, 08:22 PM   #153
wintermute is offline wintermute  Australia
just another
wintermute's Avatar
How does a 1/3 octave smoothed curve look? That will smooth out a lot of the room effects making the general trend more clear.
The rise between 1 and 3K I'd look at trying to flatten out as well. Generally people go for gentle down slope from bass to treble or the smiley curve (up at bass and up at treble) not usually a hump in the midrange area.
Tony.
Any intelligence I may appear to have is purely artificial!
Photography (another hobby)
Old 8th January 2020, 09:19 PM   #154
1/3rd smoothing: 20200107basscorrectioneqsmoothingonethird — imgbb.com
Old 12th January 2020, 01:09 PM   #155
And it's final, we're done!
My father in law and I spend a day isolating the innerworks of the speaker and closing all airholes completely (just to be sure) and then we went outside for measuring.
First response was after 6,5 ms so that got me some pretty decent gating for the mid/tweeter part.
Here we go for the results
Flat tweeter: 20201101-Tweetmet-Piet — imgbb.com
Flat mid: 20200112-midflatpiet — imgbb.com
Flat woofer (with filter, did not save flattened response): 20200112-flatwoofermetfilter — imgbb.com.
Since the woofer could be made flat up to about 1100 Hz and the mid down to 350 Hz I chose a 4th order LR filter at 500 Hz. For the tweeter and the mid I chose a 2nd order LR filter in the hopes of a natural sound (not to obvious the sound was coming from the tweeter). I chose 2800 Hz as a crossover since the tweeter was flat up to 700 Hz (almost) and the mid could handle up tot 10KHz. The tweeter was inverted (because of the LR2 filter).
This is the result: 20200107-LR45001600 — imgbb.com
Full sweep: 20200111-fullsweepfinalfilters — imgbb.com.
The result inside was stunning for the mid/tweeter section before DIRAC, with superb clarity (unlike anything I've heard).
I just measured in DIRAC and I am again very impressed with the results of base control. I had a few room nodes which DIRAC filtered out greatly.
That is the end of my project so far.
Old 14th January 2020, 09:00 AM   #156
just another
wintermute's Avatar
Great! sit back and enjoy. After some time the bug will bite again
Tony.
Old 14th January 2020, 09:27 AM   #157
Hey Tony, that is probably so. I even constructed an extra preset (LR4 at 3500 Hz) since this should result in the best phase result. What is really nice is that DIRAC only needs to correct up to 200-300 Hz and above it the frequency response sort of follows the desired curve already (Screenshot-20200113-214431 — imgbb.com).
Old 14th January 2020, 10:03 AM   #158
TNT is offline TNT  Sweden
I would probably correct the midrange "peak" - maybe the one higher up also. As it is close to the xo maybe its best done with the dirac system?
Filter recommendation (using Hypex Software Design)-eq-png
More distortion to the people!
Old 14th January 2020, 12:57 PM   #159
Yes Dirac covers this very easily.
Old 14th January 2020, 01:53 PM   #160
Dirac filter applied. But I kind of like the sound when correcting only up to 300 Hz or soScreenshot_20200114-145215.jpg
Filter recommendation (using Hypex Software Design)Hide this!Advertise here!
Hypex AS2.100 not discovered by Hypex Filter Design software rskriver Software Tools 0 24th July 2019 04:31 PM
Hypex DSP Design software and data files eriksquires Class D 0 1st January 2016 10:04 PM
Active filter design software lochness Tubes / Valves 25 11th July 2008 01:04 AM
design software for active filter dick van nierop Chip Amps 7 20th March 2006 05:25 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
