Audio power distribution box
Old 22nd November 2019, 12:26 PM   #21
AllenB is offline AllenB  Australia
AllenB's Avatar
Sure, I can see what you meant. I think one way will show a rising impedance with level and the other, falling.
Old 22nd November 2019, 03:23 PM   #22
bentoronto is offline bentoronto  Canada
Originally Posted by Max Headroom View Post
I'm talking tube amp transformer output so it needs some minimum value of resistance as load.
I'm confused. I thought you wanted distortion and now you are saying you want to set up the amp so it doesn't distort. Should the musician have a choice out of a whole bunch of different kinds distortions to choose from?
Never thought I'd ever see a DIYaudio discussion of trafficking in distortions.
B.
HiFi aspirations since 1957. "When the toilet paper of Experience is depleted, the backside of Reason goes unwiped"
Old 22nd November 2019, 05:36 PM   #23
weltersys is offline weltersys  United States
weltersys's Avatar
Originally Posted by akis View Post
"was sent at various levels from 1 to 8 watts (a 9 dB range) to an Epiphone 8” speaker, standard issue in the Valve Jr. combo “5 watt” amp."
What was the wattage of that speaker? Our speakers are 75W (stonehenge), 150W (tonkers) etc
Most of the stock 8” guitar speakers are in the 15-25 watt range.
The Eminence 12” Tonker is nominally 8 ohms and has a 1 watt one meter sensitivity of 101.5 dB, so at just 2.83 volts, nominally 1 watt, it is already pretty loud. The Tonker has a low .8 mm Xmax, , so will distort without much drive level, but rated at “150 watts EIA426”, can withstand around 34.6 volts, though the impedance is much higher through the low and high range, so won’t actually see 150 watts when presented with 34.6 volts. The Stonehenge has slightly higher sensitivity, but less power handling.
The Epiphone 8” is probably also made by Eminence, may be similar to the Patriot 820H, a four ohm 8” with 1.59 mm Xmax, rated for 20 watts, 96.1 dB sensitivity at 2 volts.
Understanding Loudspeaker Data | Eminence Speaker
The Patriot 6” 620 (also 20 watts) at 94.6 dB sensitivity has only .4mm Xmax, so should distort at a SPL about 6 dB lower (1/4 the power) than the 820H, actually 7.5 dB lower when sensitivity is considered. The Fender 8” I tested may also have only around .4mm Xmax, considering how much more distortion it produces than the Epiphone.
The 620 may have a similar distortion profile to the Tonker while playing 13 dB less loud, like reducing 65 watts to .5 watts without using any load resistors.
Without actually testing the guitar speakers, hard to determine whether their distortion profile matches the preference of a guitar player. Fortunately, little guitar speakers can be had for the price of a couple sets of strings, find the flavor you like!
And to answer Ben's question:
"Should the musician have a choice out of a whole bunch of different kinds distortions to choose from?"
Yes!
Audio power distribution boxHide this!Advertise here!
Big Bear Audio - Lundahl Distribution UK Big Bear Audio Vendor's Bazaar 2 27th November 2013 11:22 AM
How to build audio distribution amplifier? lovelikecute Instruments and Amps 13 15th August 2013 06:55 PM
Audio Distribution schematics Boss_Ronald Solid State 0 20th August 2008 11:52 AM
Audio Distribution - balanced redrabbit Solid State 24 13th July 2008 03:49 PM
RE : audio distribution joensd Solid State 14 1st July 2003 01:40 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
