Open Source "Tower XL"
Old 20th September 2018, 06:28 PM   #11
KaffiMann is offline KaffiMann  Norway
Fanatic
KaffiMann's Avatar
Yes, I've been looking at some Faital woofers. They are pricy though. A decent matching mid also drains the wallet rather quickly, not to mention a good quality tweeter. Wow, I seem like "mr. Optimistic" himself all of a sudden...
Things are starting to happen, work in progress: https://kaffimann.com
Old 20th September 2018, 06:36 PM   #12
Paul Vancluysen is offline Paul Vancluysen  Belgium
Aatto,
The sims, all B4 alignments.
BMS 15N630
Cabinet = 125 L and tuned at 39 Hz, F3 = 40 Hz and sensitivity = 96 dB half space
Faital Pro 15FH520
Cabinet = 130 L and tuned at 39 Hz, F3 = 39 Hz and sensitivity = 96.5 dB half space
Eminence Kappa 15FLA
Cabinet = 145 L and tuned at 39 Hz, F3 = 40 Hz and sensitivity = 97.4 dB half space
The Eminence Kappa needs more volume, because of lower Qts and higher Vas. Highest sensitivity, 91.4 dB full space ... almost the 92dB full space.
The Faital has a high Qms = 10.25, interesting...
Old 21st September 2018, 01:43 PM   #13
Aatto is offline Aatto  United States
Aatto's Avatar
So Eminence Kappa 15FLA is the winner so far.
this FaitalPro 15PR400 also looks good but need larger cabinet, Humble Homemade Hifi used it in Calpanos (200 liter tuned to 37Hz -3db. better priced than FaitalPro 15FH520.
I used to be with it, but then they changed what it was, and now what Im with isnt it. And whats it seems weird and scary to me. - Grandpa Simpsons.
Old 21st September 2018, 01:50 PM   #14
EarlK is offline EarlK  Canada
Originally Posted by Aatto View Post
Achieving a high efficiency 8 ohm speaker with low extension is the main factor here and all falls under woofer's territory, so I suggest to start with possible woofer candidates.
I would suggest a poll is in order to see how many users will accept a 15" woofer > especially when a pair of 12" woofs would also ( more than ) deliver the SPL & extension requirements.
A pair of 12" woofers can offer more design flexibility ( ie; TMWW, > even a 3.5 arrangement ) and give a nicer looking tower ( IMHO )
Old 21st September 2018, 02:00 PM   #15
Aatto's Avatar
totally agree about the looks and the fact that if we can achieve that with smaller woofer there's no need for a huge 15 incher, but finding a woofer even within 15 inch range to meet needed specs is not easy, 16 ohm woofer for a TMWW also not easy to come by, so what do you suggest ?
Old 21st September 2018, 02:17 PM   #16
mbrennwa is offline mbrennwa  Switzerland
mbrennwa's Avatar
We've had that discussion before. I fully agree with your, except that using two woofers means you'll have to find suitable 16 Ohm drivers. The choice is rather limited compared to the 8 Ohm world.
Group buy for augerpro waveguides for Scan Speak tweeters -- elliptical version -- circular version
Old 21st September 2018, 02:28 PM   #17
Aatto, mbrennwa,
Right, I forgot you're currently set on a minimum 8 ohm impedance.
For my own purposes, I always allow 4 ohms as the minimum impedance.
You may find that others may accept that lower impedance choice ( POLL ? ), once they understand the trade-off realities ( when pursuing sensitivity ).
Old 21st September 2018, 02:47 PM   #18
mbrennwa's Avatar
That was already covered in the poll of the "part II thread".
Old 21st September 2018, 03:14 PM   #19
Really?
I guess I missed some implied meanings that were baked into that poll (since there's no specific mention about impedance limits in any of the polling questions that I can see).
I now wonder how many others may be in the same boat (regarding confusion over "what's an allowable impedance curve").
Old 21st September 2018, 03:23 PM   #20
Aatto's Avatar
Most of the specs are covered in the first post of this thread but please let me know if I missed something or if it is vague
Open Source "Tower XL"Hide this!Advertise here!
BMS 8CN552 8" coax (Pair) "point source" Soldermizer Swap Meet 0 14th June 2017 04:10 PM
"Digital Line Level" and "Dital Source" forums.. terranigma Forum Problems 7 13th December 2016 06:31 PM
My next project open baffle 4way (15" 12" 10" econo waveguide) help charlie2 Multi-Way 21 28th September 2015 05:25 PM
Delivery Source for the 10cm "HR Vocal Driver" from "4722" LENS (47-lab) wanted tiefbassuebertr Full Range 1 5th September 2014 09:17 AM
"open source" projects need to be done differently prairiemystic Forum Problems 10 5th March 2010 07:17 AM
Copyright ©1999-2019 diyAudio
