Grounding question
Every inter-module connection needs two wires.
Keep every two wire connection as a close coupled pair.
Twisted, or coaxial, is slightly better if the size and type of cable suits.
eg.
From power supply A you need two wires. A dual polarity PSU needs three wires, twist these as a triplet.
From power supply B you need two wires. A dual polarity PSU needs three wires, twist these as a triplet.
From Audio Source Left channel you need two wires.
From Audio Source Right channel you need two wires.
Speaker Left output needs two wires.
Speaker Right output needs two wires.
Transformer secondary to rectifier needs two wires.
Install all those two wire connections.
Now compare your assembly to the schematic and find any missing connections.
Unfortunately the PCB layout designer did not agree with this most basic philosophy.
He has provided many connections as single pads. He has forgotten that current cannot flow around a circuit unless a route is provided for the return current to go back to it's source.
it's more about the connections on the circuit board - there is one marked '0v', and one marked 'T'. My understanding is that the 'T' goes to the main star ground, but the '0V' - is that for the 0V return of the low current supply, or for the signal ground?
this is what i use....
post4 is wrong. Pavouk.org got it completely wrong and AJT should never have copied it. He has been told before and chooses to post this erroneous layout yet again.
Never take your audio ground to the main charging node between the smoothing capacitors ! NEVER !
Many will disagree with you on that. The input gets it's return own path to the star ground. What's wrong with that?
The problem is that there does not appear to be a signal ground connection on the board. Unless, as I said, that is the '0V' connection pin near the output transistors, which seems a bit odd.
You need to do a bit of reverse engineering comparing the schematic to the layout to find the best place to tap into the return part of the circuit, for least interference.
That will not be easy.
i have been using that layout even before Pavouk published it, as early as the early 90's
it works for me, no reason it will not work for others....
nothing is....
the speaker negative or return wires go back to the star....
never use one wire for the two channels, run them using separate wires,
i never run speaker grounds to the board and then to the starr,
i use separate wires....
so you seem in the schematics there may be fewer lines,
but in the actual buildm there are more wires than the schematic called for....
Are you disagreeing or stating the opinion of other Members?
The charging node in between the smoothing capacitors passes enormous pulsing currents. That is the second worst place to take your main audio ground to for a reference voltage. The worst place would be the centre tap between the two Secondaries. Except there is an even worse location. Taking the Main audio ground to the chassis where the centre tap is also connected.
Many others are now confirming that the Main Audio Ground (MAG) should be located separately from the PSU common node. Then attach a voltage reference wire/trace from MAG to PSU Zero volts. This voltage reference connection can be short, or long. But it must be a finite length.
I prefer to locate the MAG at the power amplifier. I try to locate it at the centroid between the Speaker Return terminal, the Signal Return terminal and the PCB Power decoupling ground. It helps if these are fairly close to each other. This implies that the MAG for each channel is separate from the MAG of any other channel.
I prefer to locate the MAG at the power amplifier. I try to locate it at the centroid between the Speaker Return terminal, the Signal Return terminal, The PCB Power decoupling ground. It helps if these are fairly close to each other. This implies that the MAG for each channel is separate from the MAG of any other channel.
Sorry, I didn't realize you were nit picking about how the star ground was drawn. using just about any decent power supply board negates the issue.
? are you denying that the charging currents pass through the PSU common node between the smoothing capacitors?
...why call it ground then?
I did not call it ground.
that point i ground zero......
PSU Zero Volts would be an unambiguous term. But it's certainly not "ground zero".
Andrew'a preference is not Tony's preference....simple as that...
We can have different preferences. But recommending a bad layout does no new Member any favours.
