Hi Simon
Fs of the 10 is ~32Hz & Qts of ~0.77
Fs of the 12 is ~30 & Qts of ~1.46
So I think the combination of both drivers will work quite well, given floor reflections.
Baffle width would be again 450mm, side wings o rU frame of about 300mm
Stuey
you drink too much in the West, I was good boy drank water and tea
regards
Ted
Stuey
regards
Ted
This took a year
My friends took delivery of these a while ago, but it was only on Xmas day when we went for lunch that the speakers were hooked up and listened to.
Good clean bass and finally midrange sounded like it should, too loud and they loose definition as power handling is limited, but in this instance the amp runs out of steam before the speakers.
I am reasonably happy with these, SWMBO concurs, but the XO took a lot of work to tame the midrange ( try and try again guess work and listening ) the damping blanket behind the drivers really is needed in this room.
Lounge room is 8 * 12 Meters and new owners needed the speakers along the wide wall, tall vaulted ceiling 5.5 meters tall
