6 ohm speakers are not common and must be specially sourced, so if Ibanez went all the trouble to get them, instead of easy off the shelf 4 or 8 ohm ones, it means your amp can NOT drive 4 ohm (which will sink to 3 ohm at some frequencies).
If they work, leave as is, Ibanez are no fools and use good parts.
If broken, replace with 6 ohm same type IF you find them, OR 8 ohm, which is safe.
Ibanez T150s
Does any one know what module is used in this combo amp?
Link to picture
Imgur: The magic of the Internet
This is the module
Link to picture
This is the module
