6 ohm speakers are not common and must be specially sourced, so if Ibanez went all the trouble to get them, instead of easy off the shelf 4 or 8 ohm ones, it means your amp can NOT drive 4 ohm (which will sink to 3 ohm at some frequencies).
If they work, leave as is, Ibanez are no fools and use good parts.
If broken, replace with 6 ohm same type IF you find them, OR 8 ohm, which is safe.
I dbl posted in the d forum so I deleted this one
I posted a link to a picture of the module.
I am trying to determine the make and model of the module.
Thanks again
Thanks again
Ibanez T150s
Does any one know what module is used in this combo amp?
Link to picture
Imgur: The magic of the Internet
This is the module
Link to picture
This is the module
Sorry but there´s nothing readable there.
IF you dare, unscrew it from chassis and tke a couple detailed closeups from the other board face, showing any labels there.
Although if it works fine, I wouldn´t mess with it.
Whay´s your purpose?
Increase power?
Replace speaker?
Increase power?
Replace speaker?
