Use any heavy-duty 250V switch.
Typically same-as your Power switch.
Yes, 350V is "over rating". But a "250V" switch is expected to stand LARGE surges and currents and arcing. Vacuum-cleaner motors, incandescent lamp filaments, etc. The secondary of a PT is not an "infinite source" and doesn't abuse the switch nearly as much as most loads the switch is designed for. Fender and Marshall used 250V switches for many decades, few failures.
Diodes are cheap insurance
Except that we beat the heck out of valves in most (western) guitar amps and they fail far more often than in "normal" usage.
Indeed the very first mod in Premier guitar's Immortal Amp series is exactly this: diodes in series with your rectifier.
Diodes in the anode of EZ81 have no sense. You would remove them.
Rectifiers vacuum tube/valves has been working pretty fine much time ago than ss diodes was born.
output transformer turns ratio /impedance?
Hello all
The amp design I am working on,I used a doner chassis that came complete with the mains transformer and output transformer along with ec83 pre and el84 output in push pull
It was a diy build from way back when
The output transformer I assumed was a match and has 2 output impedance's of which I wanted to find out if they were say 4 and 8 ohm etc
I put 4.7ac into 1 of the sec pairs and got 189vac on pri
so 189/4.7 =40.21 turns ratio
40.21x40.21 =1616 then x 4 ohms = 6464 or 8 ohms 12928
the 2nd pair 192/4.7 =40.85
40.85x40.85=1668 x 4 ohms =6672
and 8ohms 53376
I am confused as this doesn't match what push pull el84 need and I am not so confident with my maths either
On measuring the pri there are 3 wires ,1 being center tap.I measured across the 2 and not the center tap ,did this make the readings I have ?
also my multi meter ac settings are 600 and 200vac only?
Thanks all
Hello all
and 8ohms 53376
Thanks all
...the 2nd pair 192/4.7 =40.85
and 8ohms 53376
...not so confident with my maths either...
My figures say 13,350; 13k not 53k.
All the rest looks OK.
Are you sure the "4.7VAC" stays at 4.7V when connected to a low-impedance winding? Did you measure that with the transformer connected?
Two windings making 189V and 192V is very odd. You expect them to be the same, or very different, not 2% different.
It needs to switch 350v dc at about 100ma
You won't find one, so switch the AC only.
Indeed - you need to do your switching up stream of the rectifier.You won't find one, so switch the AC only.
Switching DC power above 12V is a specialist activity: in AC any arc-over shuts off every half cycle. In DC the arcs never have to stop.
I have a 200W amp on the bench with 70V rails; fried output transistors and speaker protection relays welded shut.
Even 12V will melt a switch if it's badly designed. Ask anyone with a '70s British car with electric windows or sunroof.
- Live Sound
- Instruments and Amps
- marshall 18 watt tremolo psu question
