Hello. found a bunch of el84 I can use to drive a pair of kt88. I understand can be a very good candidate for that instead a 12au7.Unfortunately I did not found in any datasheet design refereces how to implement it in triode mode.I expect a moderate gain around 20 into 100k load with ca. 3v at input.
Can I conect screen grid to plate and use the graph caracteristics and design like any regular triode?I don.t know how to design the stage. Can You help me with one sugestion.please? Thanks.
http://www.4tubes.com/DATASHEETS/SCANS-Original/E/EL84-TRIODE-MODE.gif
The grid leak should be max 220k as for pentode or can I do it as big as 1M.for instance.
The GE data sheet says 300k with fixed bias, and 1M with cathode bias, as the maximum Rg values.
These should still apply.
Patrick Turner often uses EL84 as drivers of power tubes.
Here is just one example from his website.
80W-AB1-amp-2014
and another for a 300W Amp
http://www.turneraudio.com.au/300w-1+2-schem-input-driver-output-jan06.html
Note he uses centre tapped choke loads but that is not really required.
Ian
80W-AB1-amp-2014
Ian
I used a SV83 - Russian relative of the EL84 - to drive a 300B. Not my idea - Thorsten Loesch did this with his Legacy amplifier.
http://community.fortunecity.ws/rivendell/xentar/1179/projects/legacy/Legacy.html
Most of my builds have used pentodes - either the EF86/EF40 or a 6J7/6SJ7 - for driving the output tube. Simple... and plenty of gain for negative feedback.
Thank you for kind replies. One more question please...Saw in datasheet max g2 voltage to 300v. That means max peak voltage.please? I wonder for what consideration the limited value is 300v? Maybe for triode conection the same demands will not be applied here and can raise the g2 max peak voltage up to 560v.exactly like for plate as time are connected together. I asked cause a supply 450-500v is more convenient for me.with a 10-12k at ca.15mA draw will put the anode arround 300v at idling what should be max acceptable .Thanks
Peak Heater Cathode Voltage = 100V
http://www.tubebooks.org/tubedata/HB-3/Receiving_Tubes_Part_1/6BQ5.PDF
So you would most likely need to elevate the heater supply.
Ian
Ian
Hi. I did not found any info how much plate current should I draw for el84 in triode mode to keep internal resistance into a optimal 2-3k and how much total distorsoon should I expect from a differential without a ccs compensation in a tail.please? Thanks.
What should be considered a good point to start.please?
- Live Sound
- Instruments and Amps
- EL84 driver stage
